Oil
Re: Oil
Where are you located? How many miles on the car?
Re: Oil
just put what your owners manual recommends for your climate.
Re: Oil
I'm a Valvoline fan Larry
Re: Oil
whatever is on sale. i don't think there's much point in buying expensive engine oil if it is being changed as regularly as it should. trans and diff oil, i can justify the higher cost of synthetic since you don't change that stuff very often, but that's it for me.bisho23 wrote:Iowa but like what brand you guys use
i don't like cheap oil filters though. i've had one quaker state one that gave low oil pressure and two frams that had the gasket stick to the block when i replaced them. i didn't know at the time to always check that so my wife's car pissed all its fresh oil out. live and learn: always check the block before installing the new filter, and don't buy fram or quaker state.
Re: Oil
I find synthetic is better, smoother running better cold starts and more fuel economy, and longer change intervals with good filters
