Hi from Australia
Re: Hi from Australia
Drift ,where do you live? I have a son that has lived in Perth for the last 5 years, if you know any thing about BEER -- one of my fevorite subjects---- He has won best amature brewer in WA for the last 3 years, this year he won best amature brewer in Australia. Sorry for the rave---- like drifters Larry
if the engine sat for while, it could be the oil rings are gummed up and not doing their job. something like a Seafoam treatment was for exactly this kind of problem.
Try using Seafoam, (or what ever equvalent you have there) in the oil and down the combustion chamber to loosen the gummed up rings. You are supposed to drain the oil after the treatment.
Hi Larry I am on the complete other side of the island! On the sunshine coast.
Shoot me the name of his beer I will take one for the team and put myself on the line to try it.
Does anyone have any pics of this sea foam stuff so I can find it or at least an equivalent.
We have some three bond stuff here but its hard to say without knowing what its name and intended use is.
- Mattel
hi driftke, I put this on the parts, parts thread but will put here instead re; rear reflector
Hi Driftke, My Tercel in Melbourne had the same reflector. it pops right out and all you need to do is carefully pry off the interior cover to the rear hatch reach into the door and you will see the lugs that hold the reflector in place to the plastic plate surround which will fit an australian plate. the reflector will probably just be siliconed in. you just need to pop it out. reconnect the numberplate lights (mine was just a socket). I then removed the external plate holder and put some plastic plugs in the holes in the body work. good luck mate. only nsw and vic had these reflectors... collectors items. haha
true?
I have thought about remaking it or redoing it with a fresh piece of acrylic and maybe chucking a dim light behind it for
maximum rep on the highway haha.
I put a can of decarboniser i guess you could call it through the car today but it started running like ass, I took it for a drive
and it drives a smidge better but wouldn't idle afterwards and for some reason the petrol in the bowl was bubbling and boiling.
So ill fire it up tomorrow and see whats up. I noticed it seemed to wreck the adhesive between the adapter plate and the carby.
Hopefully fixes my highway smoke woes. The more I think about it a sitting motor would get sticky rings.
- Mattel
Heres my two old Tercels worth from 12 years ago.
From what I read. some state in australia thought that the number plate holder on the Tercel was to far over to the passenger side to be seen easily (?) so Toyota had to make the aftermarket plate holder to sit behind the driver and then to make more people notice put a huge reflector on the now useless factory plate holder. I bet the original globes are in there still. I had both plate holder lights going for a while and wanted to make the reflector a disco light or a huge ass brake light.
True?
Mines exactly the same.
I might just get some tube spacers and a rectangle of translucent red acrylic and cut it into the shape and space it out and hook the number plate lights up and see if i can get a glow out of it.
government bureaucrats can be such idiots sometimes. As if someone will miss a plate on the back of a car because it is off center.Mattel wrote:[img]
"sometimes"
does anyone in aus have one of the air duct tubes that go under the steering wheel from the center console to the far right air vent? Mine is missing for some reason.
Also does anyone know where the air conditioning wires should be going or should be doing.
I have tried hooking mine up and it wont work but if I do it direct to the compressor I can get it to lock up. Would really love working air con. Even if someone just has photos of where the two wires on the compressor go or what ever.
- 83Whit3Hatch
- My tercel:: 1983 3 Door Stripper Model. Grey seats with red inserts. 5spd swap.100W 9003 bulb upgrade.
Here's a pic of what the Seafoam looks like
if the ac appears to be connected, verify the system is pressurized before you wire it directly. the system has a pressure switch that will prevent the clutch from engaging the compressor if the system does not have refrigerant in the it, it is to prevent compressor damage running without the lubricants that are included in the refrigerant mix.
I had an a/c from another car I installed in a car going to Texas, had a an A/C shop replace all of the seals and than charge it up. worked great. Several weeks later it was not working, I tested the compressor by jumping it directly. It worked, but was not putting out cold air. I shut it off and studied the wire diagram to track down the "problem", when I by passed the switch it also engaged. so there was no more refrigerant in the system, it all leaked out. one of the seals was misinstalled.
So make sure there is refrigerant in the system, the problem may not be electrical.
Interesting
Whats a new compressor worth
You guys in the states don't know how lucky you are with pricing its 150 bucks just for a gas top up here
A gas top?
AC gas top up, aka refillirowiki wrote:A gas top?
