Parts parts parts
Re: Parts parts parts
Not sure what you are referring to, but the ring and pinion is a matched set, do not mix them up they will destroy each other. the lash setting between the two is very sensitive, and unless you know how to set the lash (requires shims of a number of thicknesses), best leave it in the carrier and change out the whole assembly, front or rear, as a unit.
- Gottolovem
PeterPetros wrote:Not sure what you are referring to, but the ring and pinion is a matched set, do not mix them up they will destroy each other. the lash setting between the two is very sensitive, and unless you know how to set the lash (requires shims of a number of thicknesses), best leave it in the carrier and change out the whole assembly, front or rear, as a unit.
Their are two separate people looking for two separate parts.
One is after a 3.73 rear assembly for an 1983 car (if you have one their desperate) i do not.
The other part is a spedo gear 22 tooth vs.20 tooth
Would having the wrong number of teeth make the speedo go five mph faster that actual sped
I used to laugh at the man with a pinto
, until I became a humble servicer of a tercel
- Gottolovem
I don't know the diffrence but yes it will make the spedo inaccurategnarnold wrote:Would having the wrong number of teeth make the speedo go five mph faster that actual sped
Better than no speedo!
the person looking for the 3.73 had listed on his avatar he had an '85. so unless he has another one that is an '84 not listed, he should need a 4.10 for the '85, or the 3.73 for the '84.Gottolovem wrote:Their are two separate people looking for two separate parts.
this is confusing; I may indeed have a spare diff in my pile of parts, not sure what ratio's I have (I know I have at least one 4.10), is it front or rear they need?
- Gottolovem
Petros wrote:the person looking for the 3.73 had listed on his avatar he had an '85. so unless he has another one that is an '84 not listed, he should need a 4.10 for the '85, or the 3.73 for the '84.Gottolovem wrote:Their are two separate people looking for two separate parts.
I never looked at the avatar Peter(good catch). They are requesting a model year 1983 rear diff. She has two t4's so the avatar must be the other car
viewtopic.php?f=3&t=11598#p87792
I spoke to her on the phone and she lives on a island somewhere in Washington I belive
when I get a chance I will see what I have. If not too far away perhaps we can meet somewhere. Puget sound is an archipelago of islands, most of them have year round residences, the larger ones have bridges or highways too them. There are several prominent ones within about 30 -40 min of my home.
Crankshaft pulley expidited the
Never mind problem semi-solvedgnarnold wrote:Crankshaft pulley expidited the
Hi,
I am in australia but I am chasing the little pipe that goes to the right hand side dash vent under the steering wheel, might not be the same in the USA.
Also I am chasing maybe the little tail gate number plate surround. Mine has some weird big red thing in its place.
- Gottolovem
Can you be more specific about the pipe in question?
Perhaps a photo or even the schematic from the FSM here in this forum.
Number plate suround? Are the plates the same shape in Australia?
I can likley get the things you need but need a little more to go on PHOTOS would be great.
Will try to get some
- My tercel:: 1986, stock....so far
Im looking for an auto tranny for an 86
- Gottolovem
Sorry no autotercel864x4 wrote:Im looking for an auto tranny for an 86
