Installing trailer hitch
- Mark
Re: Installing trailer hitch
I removed the metal part out of the bumper today and I got a length of steel rectangular tubing (4"X 2") to try and replace it with. I also removed the parts of the bumper that bolt into the wagon body. I did a bit of cutting, but I mostly tore them off by hand by wiggling them back and forth. The new piece of steel is on the right:
The steel rectangular tubing sits nicely in the rubber part of the old bumper:
I'll cut/grind away the extra metal on the parts that bolt into the wagon and weld them onto the steel tubing:
I'll have to find some way of attaching the rubber part to the new steel tubing, but I don't think it will be too hard.You do not have the required permissions to view the files attached to this post.
- Mark
I was a bit worried about the extra weight of the new piece of steel, but I stood on a scale and weighed them and the new piece of tubular steel only weighs 11 lbs extra compared to the old metal part of the bumper that it is replacing. I guess an extra 10 lbs or so won't really make a difference.
Nice work. I think attaching a hitch to the stock bumper always seemed like a bad idea, not just because of the rust, but the thin sheet metal built up part is not suited for taking trailer loads like that.
I have always thought it would be fun to make all alumiumn rear bumper, and leave the heavy rubber cover off. though I would want to find a way to make it look finished, perhaps a thin fiberglass cover that looks like the rubber cover.
- Mark
One thing I noticed that I never knew before is that behind the rubber cover, there's a thick block of some kind of foam or something. I'm guessing it's for absorbing the impact from a crash. I've been rear-ended a couple of times at low speeds while stopped at traffic lights. I wonder that if this foam block wasn't there to absorb the impact, the energy would have been transmitted to the bumper mounts and maybe cracked/bent the frame. When considering material to use for a new bumper this time, I thought of tubular aluminum since it's many times lighter than steel, but I don't think it would be strong enough for towing. If I wasn't towing, I probably would have gone for it. There would also be dissimilar metal considerations with the aluminum in contact with the steel mounting hardware. Aluminum would act like an anode and might corrode/crack where it was in contact with the steel. Realistically, I don't think that would be a concern either unless the aluminum was under strain (like when towing for example).
use marine grade aluminum, and put sealant or non-metalic gaskets on the bolts, corrosion should not be a problem. With stainless steel bolts, it will never rust in place like the plain steel factory parts always do anyway.
- Mark
I finally finished the bumper. I cleaned up and painted the rear of the wagon with rubberized chip-guard paint. I actually kind of got used to how the wagon looked without the bumper, but since I've been gently rear-ended a couple of times while stopped at lights, the bumper has shown its usefulness.
The bumper welded together and bolted to the rubber cover with strips of steel:
I cleaned-up and painted it with that rubberized chip guard again, mostly to try and protect the welds from corrosion:
Back on the wagon. When I put the bumper all together I didn't bother to properly measure anything. I just eyeballed it. In hindsight, this wasn't very bright since the rubber part doesn't really line up properly on the car body. I'll just live with it for now:
Nice job. How is the clearance to the body at the center of the bumper? The original ones curve a bit to maintain a clearance.
- Mark
I found that out. In some of the pictures above you can see steel plates welded under the arms that go into the car. These act as spacers holding the bumper out from the car body. I'd say, in the middle, there is about 1/8-1/4" of clearance.
- Abletobecain
- My tercel:: 1983 4WD DLX, 1986 4WD SR5, 1985 4WD SR5, 1983 4WD SR5
Hey jimcrazy and mrdance...I see you towed a complete T4 with your T4?
Can you give some details? How far did you tow it? How did it feel? How did the towing car perform?
I have to add a reminder about towing with these transmissions. I recommend not using 5th gear while towing. I have worked on three trannys that had 5th gear problems and towing was the thing they all had in common. When i asked a local tranny repair shop about the type of 5th gear problems i found the first thing he asked me was whether the cars had trailor hitches. He is the one who said not to tow in 5th gear.
