Parts parts parts
- Gottolovem
Re: Parts parts parts
What year is your car?
Is it an sr5?
Do you have a 110mph spedo or a 80?
I'm pritty sure their is two different spedo gears I may have on but no guarantee
Is it an sr5?
- My tercel:: 1984
Oh thank you for writing! I will check tomorrow if its 80 or 110. There is a picture of it here...
viewtopic.php?f=4&t=11591
Look no further ! you have come to the right place .patience is the key .you will find one .and welcome to to the club!
I used to laugh at the man with a pinto , until I became a humble servicer of a tercel
- My tercel:: 1984
Thanks guys!....you are great. Its a 85 mile per hour speedo... if you have one that would be awesome! thanks so much
- Gottolovem
Let me look around in my stuff
- My tercel:: 1985 Tercel Wagon SR5
How about a rear differential for an '83 sr5? Mine is busted
- Gottolovem
confirm gear raito @3.73 I should have onezucabird wrote:How about a rear differential for an '83 sr5? Mine is busted
Yes 3.73 ratio is what I am looking for. What are you asking and where is it located?
- Gottolovem
Yes count # of teeth on these two gears and divide the #'s. You will prob need to put nail polish on one tooth so you know where you started
I was going to put a link to my last thread but my comment disappeared. Strange.
3.73 is the one...what is your asking price and where is it located? I am hoping to get this done soon since it's my only car right now.
- Gottolovem
This is a 22 tooth gear is yours the same it should have a stamp?boomerbabe wrote:Thanks guys!....you are great. Its a 85 mile per hour speedo... if you have one that would be awesome! thanks so much
if you have a 1985 Tercel4wd, you should have the 4.10:1 final drive, the 3.73:1 came in '83 and '84 only. Unless you changed the front and rear diff ratios for some reason.
- Gottolovem
I think the car in question is an 83Petros wrote:if you have a 1985 Tercel4wd, you should have the 4.10:1 final drive, the 3.73:1 came in '83 and '84 only. Unless you changed the front and rear diff ratios for some reason.
- My tercel:: 1984
so mine looks the same....except for the 22 tooth..mine is 20 tooth. So I am thinking if I can somehow remove my gear...put it on yours....wah lah! Im back in business. Thoughts?
I sent you a pm...with my phone...thanks so much John
