engine swap 3AC to 3A wont idle just wanna...
Re: engine swap 3AC to 3A wont idle just wanna...
i use a short piece of chain
one end to big bolt for transaxle to engine hole
one clutch plate bolt in flywheel
gnarnold
My tercel:: 1983 SR5 4x4 with a tummy tuck and a nose job and now a pace maker!
Post by gnarnold »
There are two relay looking boxes attached to the drivers side wheel well by the fuse box anyone know what those do and is there a seperate ground wire for the fan. I took out my AC didnt work any thing i should be aware of as far as wiring goes?
I used to laugh at the man with a pinto :lol: , until I became a humble servicer of a tercel :|
there is one behind the battery on the side of the inner fender well, that would be an external volage regulator. Most of the Tercel4wd had alternators with internal volatage regulators (the connecetors and wire harness is different), but some of the '83 and '84 had an external volage regulator mounted behind the batter on the inner fender. I think you might be refering to "box" that just contains an in-line fuseable link, also not common to all of the Tercels, as I recall most just have the fuse box with a square fuseable link inside it.
gnarnold
Post by gnarnold »
its these two blac k squre ones
gnarnold
Post by gnarnold »
gnarnold wrote:its these two blac k squre ones
marlinh
Post by marlinh »
Those look like aftermarket relays. Fog lights perhaps?
rer233
My tercel:: Multiple
Post by rer233 »
+1 on the a/m relays- wiring doesn't look factory either.
gnarnold
Post by gnarnold »
Does anyone know where to find.the diagram thats on top of the fuse box located in the engine compartment. Drivers side by brake master cylinder
n the top of the engine
Post by irowiki »
You need a picture of it or?
gnarnold
Post by gnarnold »
Yes please
Post by irowiki »
This is from an 87 FWD, the fuse diagram on my 84 has worn off.
gnarnold
Post by gnarnold »
Is that pretty much the same lay out as the 83 4x4? Also i have a problem with the radiator ,it gets hot pretty quick and when i touch the lower hose its not hot at all , i put a new tting thermostat nre sensors new hose . But it doesnt even seem like its gettingany water in it
Gottolovem
Post by Gottolovem »
A new radiator auto zone is 100 bucks.
Almost all of the fixer uppers i buy and sell have needed one.
They get clogged up if you use tap water most people are don't realize this always use distilled water.
gnarnold
Post by gnarnold »
Well i crackedbthis while installing the themostat the stud bolt corner of the thing the hose mount hooks up too
gnarnold
Post by gnarnold »
Cant download pictures on the phone for some reason. So after replacing all sensors and thermostat and tested them they all work .what about the relay switch in the fuse box. ?
