favorite tire size for stock rims?
Re: favorite tire size for stock rims?
whoa that BIG tires with little wheel , My current 175/80R13 are great tires for Handling , they are the same since I visit you , Also same brand I have been buying since ohh almost 8 years . I was afraid they never make any more so I bought three set and store it .
While I was at Swap meet I also bought pair of emblems which it on my Sliver Streak at rear front fenders " Handling by LOTUS " .Maybe it lame but it funny driving beside the Porsche/Bimmer,etc .
What about 15" ZX2 Escort wheels with 185/65 tires? Too big?
1986 T4WD SR5 in Beater Blue
according the tire size calculator i use, those tires should only be about 7.5% over stock tires--my 185/80R13 were 8.15% over. sounds like those would be fine, eli.
might try a 185/60 tire on the 15" wheels, should be about the right size. Off-set might cause it rub in a tight turn, depends on how much off set is on the wheels.
Cool, thanks! I will post pics when I get them on. They are 5.5" wide, which was another concern...but I think they will ride great. It has to be better than what is on there now.
I went with 14" star wheels and 185/65 tires. Seems to work really well. $100 from CL, and the tires are probably more than 70%.
I think they look pretty good, too!
- GLet71
- My tercel:: '87 6-spd SR5 4wd Wagon
Do you have any kind of suspension lift to accommodate this tire size Peter, or would this fit on my stock T4 as well?Petros wrote:stock steel is 5", factory alloy is 5.5". I have 14" x 6" alloy wheels, with 195/60 tires, no fit problems.
Love your new set up elirush, I am hoping to join you in your snazziness soon~
Currently:
Formerly:
Formerly:
- My tercel:: "Bones" 87 SR5 4wd wagon
Your 86 looks great!
I have no lift, but I have the front springs for AC and I removed mine, so there is perhaps 90-100 lb less weight in the front.
RockAuto has Tercel replacement springs pretty cheap, get the 4wd with A/C springs, they are about 3/4" longer.
- GLet71
Would half a mm (.51mm or .02") difference in overall diameter lead to disaster? If I have four 195/60/14's and a 185/70/13 for a spare, how long could I go with the spare in case of a flat? The difference in overall diameter is 23.21" and 23.19" respectively.
Tire 1 - 195/60R14 Tire 2 - 185/70R13
Section Width: 7.67 in 195 mm Section Width: 7.28 in 185 mm
Radius: 11.60 in 294.64 mm Radius: 11.59 in 294.38 mm
Circumference: 72.91 in 1851.9 mm Circumference: 72.85 in 1850.3 mm
Revs per Mile: 896.1 Revs per Mile: 896.9
Currently:
Formerly:
Formerly:
Interesting - when I installed the Mazda Daisy wheels, I went with a Kumho 185-60R14 size, to keep the speedo error virtually nil.
Being (occasionally) frugal, I did not want to pop for a 5th tire and steelie, so I kept the spare as the OE 175/70R13 Sumitomo I'd installed in 2005.
Since the diameter is virtually identical, I figgered it would make no difference at all.
It looks like your 14" size is only 0.2% larger than the 13", so...
ditto on what tom is saying. i think the size is close enough that as long you don't run it for too long, it would be fine. i've seen tercs driven with one really low tire and mismatched tires (same sizes, though) before and it hasn't been a problem or made a difference.
The lighter wheels and just barely bigger overall diameter did make a heck of a difference.
So what the largest tire size you can get away with on a 14" wheel with stock suspension ?
^Elirush those wheel look sick on your terc, are those VW ?
195/60x14 is about the limit, when I bottom the front suspention the tire just rubs on the screws that hold the plasitc fender liner to the fender lip.
