gas mileage
Pi times diameter equals circumference. So if our tires take 913 revs per mile, thats a circumference of.. 5.783 feet? So those 10% increases are 6.361 feet. That equates to 830 revs a mile. Almost a full 100 revs a mile less. Thats 100 revs a mile AT THE WHEELS less at 60 mph, which will likely be in 4th or 5th, so thats, what? 350-430 RPM's less? Or am I just too tired for my own good.
not too sure...I use....
<a href='http://350zx.com/tire-wheel.html' target='_blank'>http://350zx.com/tire-wheel.html</a>
Seems the calculations vary at times...or maybe I didn't enter the data correctly...............
I would suggest trying 185/65R14's. I know they work, I tried them out. My folks have a Passat and it has those tires with 14x6 rims, bolt pattern 4x100 and it worked fine. I tried this a good while ago. So let me calculate....
175/70R13 to 185/65R14
Wheel RPM's at 75
1113---------1074 Not a massive decrease, but enough to get a difference. And they ride nice with proper tires.
3% speedo error (Speedo on 175/70R13 reads 75, 185/65R14's read 78)
0.41 inch increase in ride height (Woo-hoo!)
0.39 inch increase in tire width. This means that assuming the contact patch is 1 inch long, that is an increase in .39 square inches road contact. Assuming 5 inch width, that means you'll increase contact patch size by 0.39 cubuic inches, attaining 5.39 square inches of contact. My not sound like much, but it is about an 8% increase in contact patch. Better traction there.
I have not tried bigger tires, so dunno how well they ride, but it may be that much better.
So not I'll comp the 175/80R13.
75MPH Wheel RPM's
R13 R14
1050 1074
Not a massive difference. Perhaps you would try these to see if you could get a 3-4MPG gain and still have nice handling.
To give an idea, we have driven at 135 MPH in the Passat with this tire size and still it handled well.
Wheel RPM's at 75
75MPH Wheel RPM's
R13 R14
1050 1074
