It starts but doesn't idle or stay running
Nordical25
My tercel:: 1x86, 2x87
Re: It starts but doesn't idle or stay running
Post by Nordical25 »
Paul wrote: Fri May 31, 2024 9:41 am That original connector / disconnect might be hard to find. You might try replacing it with an insulated spade disconnect like the yellow one pictured for heavier gauge wire.414d8TcMI7L.jpg Disconnect the battery when installing. You'll need a crimping / stripper tool. If you don't have one, buy a good quality tool that will do it right.
This is the way to go. I have reconnected my distributor with these kind of wires too. Insulation is very important part. Especially if original wire has positive voltage.
MarvinElliott
My tercel:: 1984 sr5 wagon 4wd
Post by MarvinElliott »
Hi
I drove my car for the first time today and now it won't get gas to the carburetor I know it's getting gas from the tank and the fuel pump is pumping but it won't get to the carb and I know the fuel filter is not blocked
If you have the answer please help me 🙏😭
ME,
There is a small screen filter on the inlet pipe into the carb (in the carb), unless a PO has been in and removed it. The float should be checked as well, it might not be letting fuel in. There is a “sight glass” on the bowl that can be observed, but with limited space and 40 years of dust,etc., I’ve never had much luck using it.
NWMO wrote: Wed Jun 19, 2024 6:28 am ME,
I agree with this. Take the air filter housing off and wipe the glass with a rag. The fuel level is difficult to see even at the best of times because you're looking at a clear liquid through a thick chunk of glass but I have found if I rock the car gently I can see the fuel level when it bounces around a little. If you definitely cannot see the fuel level, the float bowl is either empty or too full.
MarvinElliott
How do I activate the windshield washer?
MarvinElliott wrote: Sun Jul 14, 2024 4:56 pm How do I activate the windshield washer?
Press the button on the end of the windshield wiper stalk.
MarvinElliott
Ok the stick broke off a long time ago I still have it but I don't know how to put it back together
MarvinElliott
And do the 84 model's have catalytic converters
SirFoxx
Post by SirFoxx »
MarvinElliott wrote: Wed Jul 17, 2024 8:03 pm Ok the stick broke off a long time ago I still have it but I don't know how to put it back together
youre better off finding another column switch assembly
viewtopic.php?t=16285
1982 4dr Tercel (RIP)
SirFoxx
Post by SirFoxx »
MarvinElliott wrote: Wed Jul 17, 2024 8:06 pm And do the 84 model's have catalytic converters
yes, all generations of usdm tercels left the factory with catalytic converters.
MarvinElliott
Ok where are they located on the exhaust
MarvinElliott
And do you know how big in diameter the exhaust is
SirFoxx
Post by SirFoxx »
MarvinElliott wrote: Fri Jul 19, 2024 10:20 am Ok where are they located on the exhaust
do you know what a converter looks like? it right after the downpipe. pipe diameter is either 1 7/8 or 1 15/16. just take calipers to it and check.
