It is a possibility as to what I'll be doing next. I want to try a few more things before I go crazy. The car ran perfectly fine until I did a few doughnuts in an icy parking lot and then it started struggling. I was unaware the thermostat was stuck and think that probably didn't help. But it was extremely cold and the temp gauge didn't get above half.Nordical25 wrote: Wed Feb 16, 2022 11:26 pm Swapping a new carb can work if a new gasket kit cannot fix issues.
Yet another carb question...
- MrWrench
Re: Yet another carb question...
1983 AV-II Sprinter Carib.
- Nordical25
- My tercel:: 1x86, 2x87
I see. Then this sounds a lot of a dirty fuel system issue to me. Your engine pumps a lot of fuel due to high rpm and due to mechanical fuel pump when you do doughnuts with your car. You have also throttle open so lots of fuel and air flow through carb. So if a new carb will fix this issue, then you want to also consider cleaning your fuel system (lots of dirt inside tank goes to carb). Has your car been unused occasionally? Then a tank can start to rust.
And do you use ethanol fuel? If the ethanol content is over 5%, the ethanol starts to "clean" your system, which can cause clogged carburetor if you don't have a clean tank. There is another fuel filter inside tank but it can get broken, which could help to jam your carb even worse if you drive without fuel filter in the engine bay. My previous fuel tank was like that. Everything from fuel pickup line to fuel gauge had rust. And lots of small debris and rust inside my tank.
Stuck thermostat should be ok then if you can trust your temperature gauge. Everything below red zone should be ok according to Toyota manual.
