marlinh,marlinh wrote: Fri Jan 24, 2014 12:05 pm
The green relay on the top right is what I swapped from the manual donor car to the automatic. There is a space on the relay panel for it. The only other wiring to do is connect or jumper the safety switch at the pedal. The wiring harness has a short connector below the steering wheel. The wires were a different colour but it worked.
Do you remember what the function of this green relay was specifically? Reverse lights, neutral safety, etc.?
Doing lots of forum research as I prep for my own auto-to-manual surgery.
I will try to refer to FSM diagram(s) but wondered if you know as well.
