Tercel Part blowout! EVERYTHING must go!
Re: Tercel Part blowout! EVERYTHING must go!
Updated first post with what people want. Btw, all proceeds from this, the headlights, and the wheels will go to the server fund. Will keep the server running for a long time!
Props to you, Paul!irowiki wrote:Updated first post with what people want. Btw, all proceeds from this, the headlights, and the wheels will go to the server fund. Will keep the server running for a long time!
This is a very generous gesture!
Tom
Also updated first post with pricing including the whole shebang.
Sold Paul, thanks! I will PM you.
BAMF came, and went, and took the parts he needed plus almost all my random junk! Hooray!
that was a great deal. I was on a road trip the last week and did not get to visit the site, so I missed out. I was delivering a Tercel4wd I got from Nevada, to Massachusetts. Had a great time, visited friends and relatives along the way, did some sight seeing of historic places. I will create a travel log to post when I have a chance. lots of fun pictures.
I still have a whole shebang deal you can take advantage of Peter.
okay, what is included? I thought someone else took it all.
Look at the first post, everything colored in blue! The prices I stuck on each item are in most cases lower than rockauto and came out to about $107 total so I figured $90 for the whole thing.
I could also make you a deal on the rear shocks (new in box)
those giant steel washers are like the ones that go under the valve springs so they do not dig into the aluminum head. there are not washers between the pistons and connecting rods. there is only a wrist pin that joins the small end of the connecting rod and piston.
- Mad_Marx
- My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
I need the headlight switch/stalk assembly for an 84 if you have one pm me with the details:)
- seancromie
- My tercel:: (ROVER) 1987 tercel 4wd
still have the timing belt kit?
Do you have a rocker arm shaft in your pile of parts?
I do still have both timing belt kits!
I do not think I have a rocker arm shaft, but will look. Refresh my memory, where is the rocker arm? (didn't sleep much last night)
