Various parts for sale
- My tercel:: 1984 SR5 wagon
Re: Various parts for sale
do you happen to have an sr5 cluster? i'm going to need one in the coming months as the gas gauge is broken.
It's probably not the cluster. The gauge is pretty reliable. Sending unit most likely, or wiring.
there is a thread in this forum on how to rebuilt/clean the fuel sending unit in the tank. it is fairly easy to access and clean, do that before you replace the gauge. The sender is the common problem, the gauge on the instrument cluster is very reliable.
i found it, i just need to get the frozen bolts out, but need to get my head gasket done first.
- 4wdEconoBox
If that doesn't fix your gas gauge let me know, I found a way to fix my gas gauge itself, as long you have a soldering iron. It's really simple to do!
