I did look into the Emition section and its just confusing a bit because there are lot more components and metal vacuum lines that mine doesn't even have but I got a lil into me by looking at the diagrams and I will keep on looking and about the "ie the vacuum advance unit on the dizzy should have the lower port hooked up to ported vacuum and the upper one hooked up to manifold vacuum" Can you mark them on a Picture I have uploaded to witch has to be connected to ? If its not any trouble of coursedlb wrote:welcome, dinka.
i want to help but don't even know where to begin. i think the best place to start is for you to read the emission section in the FSM that was mentioned earlier in the thread. it will explain some basic stuff like which devices should be hooked up to what, ie the vacuum advance unit on the dizzy should have the lower port hooked up to ported vacuum and the upper one hooked up to manifold vacuum. if you're not sure what that means, just look at the diagrams in the emission section and will show where everything goes. you just have to figure out what emission stuff your car has, which you can do by looking at it and then comparing to the devices listed in the emission section of the FSM.
in the future, can you post smaller pics? some are so large that it's hard to see things in context. that will make it easier to help you out.
12 L of fuel for 100 km of driving isn't very good mileage but with so many vacuum leaks and disconnected things, it's at least a testament to how these cars will continue running no matter what.
From all I've seen on my engine in the carb and Engine no other components such as charcoal canister, EGR etc etc my Country is a pretty hot place so most of the cold start stuff are removed and I need not to show any emission tests
