was this with or without the manifold vac advance line hooked up to the dizzy?celtglen wrote:He set timing to 13 or 15 degrees
that is too great a window for the timing. it should be clearly set between 5* and 10* BTDC, with the manifold vac advance line disconnected. the line must be reconnected after setting the timing.celtglen wrote:Thanks to this guy the timing mark in able to be set between 5 BTDC and 15 BTDC
have you tested the TP diaphragm by sucking on the vac line that goes to it? it should hold vacuum when you suck on the line. if you can suck air, the diaphragm is broken and you must replace the TP.celtglen wrote:Over the years I have had trouble setting the TP's RPMs, now it appears the TP is done, or at least unreliable.
as long as it was stored in a clean, dry place with no prolonged exposure to extreme heat or cold, it should be fine.celtglen wrote:Luckily I have a rebuilt carb I bought on eBay a few years ago. It was packed well-- I hope nothing dried out-- it hasn't been around dirt or grit.
have you checked the dizzy to make sure it's not gummed up? i had a project terc recently that acted lousy and i found that the grease in the advance mechanisms had gotten really dirty or dried up and were causing it to stick. read my post on it here:celtglen wrote:BUT it worries me that the dizzy HAS to be pushed all the way towards the FW to get to 13-15 degrees.
https://tercel4wd.com/forums/viewtopic.php? ... 563#p56857
easy to check, just remove the dizzy cap and try turning the rotor counter clockwise. it should have about 1 cm of spring-loaded play and easily return to its resting position. if not, just remove and disassemble the dizzy (not hard), clean out the old grease and re-grease it with high temp stuff.
