Tercel Towing Capacity?
Re: Tercel Towing Capacity?
That hitch looks like the ones I have seen on old Tercel bumpers. Are you building the bumper yourself or getting someone else to do it for you? Only reason I am asking is that Glet71 wants to do the same mod on his car and he was asking me about good local welders. Also, I have an old rotten bumper here with a hitch on it. I can post a picture of it if you want.
- HomeSkool
- My tercel:: 87
Id be happy to see a photo! My friend who is a welder is going to help me. Not sure if he would want to make more or not, its a weird bumper and I'm worried that its going to be hard to make look good with the part that wraps around the body on the side.
- lannvouivre
The reason for it being "universal" is that it's not uncommon for cars to have the same platform and therefor share a lot of their framework. The cars that share the hitch are probably on the same platform.
looks like a good hitch to me. i have seen similar ones on a few of the tercels i have messed with.
one had clothes hanger wire tack welded to the nuts so they could be fished into the inside of the bumper
that was a handy idea
- Gottolovem
Hahaha I love itxirdneh wrote: one had clothes hanger wire tack welded to the nuts so they could be fished into the inside of the bumper
heres some pics of hitch and wiring conveter, when stops raining I will that some pics of the one I made from sq tubing bolting it to the tow hooks
pics
pic
I would not tow much unless I did the brake up grade I outline over in the Repair Guide section. The factory brakes are too flimsy even for a lightly loaded Tercel, they over heat and warp real easy.
Even with the brake upgrade I would go real easy on it, you would not want to damage that transmission. Very light trailers only.
- HomeSkool
- My tercel:: 87
Sorry for the late reply!
Thanks so much for the photos! This makes a ton of sense!
I'm going to order my kit asap!
Thank you so much for taking the time to respond in such detail!
- Mark
Here's a link to my recent saga installing a trailer hitch:viewtopic.php?f=2&t=11403
I have not towed with my Terc. There are a lot of things to consider.Rear coil springs are pretty soft. The clutch.And,as has been mentioned,brakes.Rear axle bearings ,while adequate,are not over-engineered.
Here is something else to consider.I forget the name of the maneuver,but there is a little sideways nudge police officers or stock car racers might deliver the the rear bumper of a car in front of them to spin them out..Think of the trailer driving the rear wheels to the outside of a turn,which translates to oversteer.Even suddenly getting off the throttle in a turn could get squirrely.
Think of scenarios like a downhill switchback on a washboard road or dodging a deer where the inertia of the trailer will try to drive the rear end of the car to the outside of a turn and forward..And,of course,if you are braking without trailer brakes,the effect is increased.
Like my old Volvo 544 with 4wd.I seldom regret neversieze or threadlocker
Pit maneuver!
