Barring a differing reply from a CA-Terc owner, that would seem correct.
See: http://www.autozone.com/az/cds/en_us/09 ... oPages.htm
Second item, fig.2, vac diagram for CA cars. Check out the drawing of the distributor at the top of the diagram's link...
Repir Quesstion: Should I???
Re: Repir Quesstion: Should I???
Thanks, the diagram helps. I think it's the distributor, there's vacuum to it, but it's not advancing. I have another distributor, but I pulled off the hoses before looking at them. There's the two places to put the hoses right next to each other, and one below them. I can't tell from the diagram, but does anyone know which two to connect the two hoses to if I don't have the HAC.
Thanks....
Thanks....
Same AZ/CA diagram, but lower illustration - check the distributor and its lines/their connections in the lower right.
I forgot, also - does your car still have the under-hood stickers showing the pertinent emissions info? You might take a digital photo of them, stick 'em in the 'puter and clean them up - that is what I did with Goldie's, as they were wrinkled.
Once you hook up - I'd suggest buying some tubing and replace all of the tubing piece-by-piece (one at a time - ask me why...).
I have a Cal car too...and it has 2 diaphragms...I also have 2 Fed spare dists...they have 3.My84terc wrote: I just found the vacuum diagrams in the repair section, and I have a California car.
- My tercel:: 1985 tercel 4wd
Is that 3 separate diaphragms or 2 diaphragms with one vac nipple on the diaphragm closest to the dist and 2 nipples on the diaphragm that is farther out. The later situation is what I have been seeing on Terc's most often as the Standard Motor Products part # VC360 vac advance assy. is sold in that configuration for both CA and FED Terc wagons.takza wrote:I have a Cal car too...and it has 2 diaphragms...I also have 2 Fed spare dists...they have 3.My84terc wrote: I just found the vacuum diagrams in the repair section, and I have a California car.
That's what I meant...3 vac openings...2 diaphragms for the FED.
All you'd have to do is show it that picture of your old Tercel carcass and that poor little wagon would start crying!splatterdog wrote: Or better yet. Bring it up here to the rust belt for me. I'll give it a not so good home
I can see it now, "oh my! The paint is bubbling around my wheel wells!" then "Heavens! There are holes in me! Something must be done immediately!" and "Oh god! What’s happening! I need to go to the body shop right away, I feel as though I can’t hold myself together†“Oh to rust to death in Minnesota! Curse you cruel owner, I see the shredder jaws closing on me now, curse you!â€
87 tercel 2d
87 corolla FX
87 Mazda 323
79 Datsun 210
91 ranger
84 F150 300-6
87 T4WD SR5 blue (still have)
81 Tercel SR5 hatch
87 T4WD SR5 red
92 2WD Truck
79 F350 dually flatbed 460 Eddelbrock intake / 750CFM 4bbl (still have)
84 Corolla 4dr (current)
87 corolla FX
87 Mazda 323
79 Datsun 210
91 ranger
84 F150 300-6
81 Tercel SR5 hatch
87 T4WD SR5 red
92 2WD Truck
Re: Repair Question: Should I???
shonuffisthemaster -
I loved your Wagon Lament - sounds just like HAL in 2001...but a tad more combative.
Clever! Congrats!
Clever! Congrats!
