It starts but doesn't idle or stay running
- My tercel:: 1984 sr5 wagon 4wd
Re: It starts but doesn't idle or stay running
If it is the choke why is it stuck open
You have to investigate that to figure it out. Once the engine has warmed up, the choke should stay open in the vertical position. If it's stuck open all the time, you have some investigating to do. Sometimes the linkage that connects the choke valve to the throttle can get stuck. Remove the air filter housing so you can see it clearly and lube it with rust penetrant, use some needle nose pliers to move the linkage and make sure it isn't stuck. Sometimes it's easier to disconnect the linkage at one point so you can determine if the linkage is the problem or if the choke valve itself is just stuck.
How do I check the oil pressure if it doesn't have a gauge and if it does where is it
To check the oil pressure, you need to get an oil pressure gauge and an adapter. Then you remove the oil pressure sender from the block (it's the big funny-looking nut by the oil filter), put the adapter in, then connect the oil pressure gauge fitting. Let the engine warm up to normal operating temp to get the oil pressure reading. Do a search on here for the specific adapter you need, it's an oddball one and I can't remember what it is.
Is your oil pressure light coming on sometimes?
When I first turn the key to the lock position it comes on on the dash but once I started it doesn't come on
That's normal. If it flickers or comes on at idle once the engine is warmed up, that indicates either low oil pressure or a faulty oil pressure sender, so it sounds like your oil pressure is likely fine.MarvinElliott wrote: Thu May 09, 2024 7:33 am When I first turn the key to the lock position it comes on on the dash but once I started it doesn't come on
Hi
Today I started it up and it was idling at 2000 rpm but then it went down to 1100 rpm which is still a little higher than normal and so I cut it off and back on then I took the air filter cover off while it was running to see what was wrong and I couldn't see anything wrong then I cut it off and smoke came out of the pipe from the valve cover to the air filter and so I took off the oil filler cap and smoke was coming out of there not very much but still if you know why it was smoking or why it was idling high please please let me know
Marvin,
That idle is higher than spec, BUT that’s about where I set mine. It bounces around some anyhow and 1,100 rpm idle keeps it from wanting to die at stop lights once in a while.
Well why is it smoking
I agree with Chris, your idle doesn't sound too bad to me. And the light smoke you describe sounds like it might be normal engine vapors. Just to be sure though, I would do a compression test to see if your rings or valves might be worn.
Ok thanks I thought I would have to buy a whole new engine
Hi
So usually I un hook the positive battery cable and then hook it back up to start it but this morning I hooked it up and the entire interior and head light and stuff don't work but it makes this noise near the carb if you know what is going on please tell me
ME,
If the battery was disconnected and now won’t power the dome light, you likely have a poor connection somewhere, possibly on the battery post.
There is a fuel cut-off solenoid that I believe is a safety devise. No power, no fuel movement in the carb?
Hi
So I found the problem the connecter from the positive terminal that goes to the fuse box is broke the wires have snapped but I want to get a new connector but I don't know what it is called if you know please let me know it would be very appreciated
That original connector / disconnect might be hard to find. You might try replacing it with an insulated spade disconnect like the yellow one pictured for heavier gauge wire.
Disconnect the battery when installing. You'll need a crimping / stripper tool. If you don't have one, buy a good quality tool that will do it right.You do not have the required permissions to view the files attached to this post.
