No Crank at Ignition Lock but Runs With a Push Start
The Professor
Re: No Crank at Ignition Lock but Runs With a Push Start
Post by The Professor »
SirFoxx wrote: Thu Oct 24, 2019 10:22 pmI resorted to using aviation gasket sealant to seal the washer after tightening the bolt, which seemed to help after the goo set after a few days.
Next time use some Teflon tape on the drain plug's threads, no cure time on that.
1975 Subaru SuperStar wagon
1987 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
Abletobecain
Post by Abletobecain »
Thanks for confirming. I knew there was no compression...just didn't think it would be so easy to turn.
I always goop up the oil plug threads with non-hardening gasket compound and install a homemade paper type gasket. Nevers leaks. This is a common problem with every tercel i have messed with. The plastic washers never worked. Copper only worked once in a while. The metal ones with imbedded rubber worked most of the time. The gasket compound/paper washer always works.
