thermostat housing??
Re: thermostat housing??
marlinh wrote: Tue Aug 07, 2018 9:11 amIt's dissimilar metal corrosion, very common. When you put it back together (whether you replace the housing or not) a film of silicone on the threads of the bolts helps prevent this in the future.
Now, I'm not dissing the idea of using silicone, but I always use Permatex regular antiseize (other similar brands would be OK as well) on ALL threaded fasteners when replacing them.
Opinions on silicone v. antiseize?
marlinh
Post by marlinh »
Sometimes antiseize makes it too slippery and it is easy to over tighten and strip aluminum housings. Everyone has their favourite application, basic theory don't put the bolts in dry.
rer233
My tercel:: Multiple
Post by rer233 »
I'm def. an anti seize guy too- just don't go too crazy on the re-assembly torque. Stuff makes it REAL easy to get it apart the next time.
