Broken 4wd lever on 85' Tercel
Gottolovem
Re: Broken 4wd lever on 85' Tercel
Post by Gottolovem »
2 wheel drive transmission would have no tail shaft correct?
Gottolovem wrote:2 wheel drive transmission would have no tail shaft correct?
or transfer case. much shorter in length.
jimcrazy
Post by jimcrazy »
or a rear drive shaft
Sunburst96
My tercel:: 1983 4wd SR5 faded red(daily driver), 1983 4wd SR5 Silver-blue(not running), 1985 4wd SR5 Matte Black(needs repairs), 1984 4wd SR5 White(parked)
Post by Sunburst96 »
Took a fresh picture, cleaned it off a bit. Im pretty sure this is whats left of the control arm connecting to the transmission. Also Petros, i dont see it possible to break the control arm, either. Unless you severely damaged the belly of the vehicle which is not the case. Not sure how or why this was removed, hoping for the best.
This is viewed from the drivers side. control arm facing toward ground. to left is front of car.to the right is back
He looked at his hands, he felt his body, and he heard his own voice say. "I am made of light, I am made of stars." ―Don Miguel Ruiz
1983 4WD SR5 "Old Red" Sun-faded red (Daily Driver)
1983 4WD SR5 "Frank" Sliver-Blue
1984 4WD SR5, White, (previously t-boned) still runs
1985 4WD SR5, Rhino Lined Black
Gottolovem
That looks like the 4wd shaft with the linkage arm hacked off
Sunburst96
I honestly cant tell, but it doesnt seem frayed like it was cut. Theres also a point on each end of the linkage arm where it can be unscrewed.
this one i scraped from the yard, kinda rusty and crusted.
Gottolovem
Gottolovem wrote:That looks like the 4wd shaft with the linkage arm hacked off
Ok twisted off
I'm questioning why it was removed in the first place.
Check that gear raito :oldgeek:
Gottolovem
I can see the spedo cable on the corner of the photo.
Take a set of channel locks and see if the 4wd shaft moves back and forth does the 4wd light come on in the dashboard when you move the shaft?
Perhaps it's not the original tranny and install was incomplete.
All the more reason to confirm gear ratio
Sunburst96
Thats what i plan to do next, Im going to try and contact they guy who owned it before me, maybe i can get some answers. He said "broke off", but this was the guy who owned the tercels brother who sold me the car, and never actually drove the thing at all. Ill try to engage the 4wd from underneath.
Gottolovem
Don't trust po info get your own answers so you know for sure what your dealing with :oldgeek:
You will have to engage 4wd to confirm raito
Sunburst96
I like your style. I always say if you want something done right do it yourself :geek:
will check the ratio today. Thanks again Gotto!
Oh! now I think I see what is going on, you should be okay. that thing pointing down is the end of the tie rod that used to be on the end of linage from the lever to the selector. The linkage is broken off the rod, not the seletor shaft. So the lever arm should still be present. this could happen if the tie rod was left hanging down, or comes off the lever end and hangs down, and than strikes the ground while you are driving, and breaks off. there should be a 12 mm nut on the back side of selector lever at the tie-rod end, you may need a narrow tip vice grip to hold the other side still while you undo the nut on the back side of the lever arm. I have found this is rarely necessary, once the 12mm nut is broken loose it just spins right off with your fingers.
You should be able to put it in 4wd by pushing the lever forward (it should be in the 2wd position by the looks of it), and test the front and rear diff ratio.
