LSD Solution
JDNightFox
My tercel:: toyota
Re: LSD Solution
Post by JDNightFox »
wait so there isn't a specific model? I thought they had different models
Re: LSD Solution
he wrote one for the accura? it is based on the size of the diff. read the post.
JDNightFox
My tercel:: toyota
Re: LSD Solution
Petros wrote: Fri Aug 04, 2017 8:30 pm he wrote one for the accura? it is based on the size of the diff. read the post.
I mean I know he said it was for the Acura but I'm trying to find the dimensions for different models and it looks like they're all the exact same thing
CathodeRayTube
My tercel:: 1985 4x4 Automatic - restored
Re: LSD Solution
Post by CathodeRayTube »
How about one from an ATV/4wheeler..?maybe a more compact one from a smaller vehicle would be easy to modify..or maybe other alternatives nobody thought of..? AE86 corolla rear end swap? were our rear axles used in any other vehicle or based off of something else that might have a more common LSD or locking diff option..or a whole rear axle swap...ford ranger rear axle or something..
85 T4 DX 4x4 Automatic
83 T4 SR5 - junker/parts
94 4Runner V6
86 Mercury Grand Marquis
88 Lincoln Town Car
90 Yugo GV+
helipilot77
My tercel:: 1984 SR5 wagon
Re: LSD Solution
Post by helipilot77 »
Looks to me like phantom grip sells one that is specific to the Tercel. Here is the link. I was considering getting one and doing an in depth write-up/installation.
https://phantomgrip.com/product/1982-19 ... 20-fwd4wd/
. / TOYOTA
./_| |/|/ |]
Re: LSD Solution
AE86, rwd corolla rear axle should be an easy swap, the mount points and dimensions are the same as the Tercel4wd rear axle. It has a larger diff, and there are three brands of LSD available for it. If you can locate one there is also a good chance it already has an LSD in it since it was an option on the GTS corolla.
the only issue is the axle flange is pattern is 114 mm dia rather than 100 mm. you might be able to alter the rear axle flange to get the same dia bolt circle, would take some welding and redrilling. I do not know if the Tercel4wd half shaft axle would swap out, the corolla axles may be larger dia.
This would be a very costly option, unless you get lucky.
The conversion kit, though less than ideal, seems a less costly alternative. Perhaps better for our drive train as well, it would transmit lower forces to the drive train and transmission as well.
CathodeRayTube
Re: LSD Solution
my car is 95% driven on pavement so my first instinct is to keep it open...i have an Isuzu Trooper im planning to turn into the Safari truck..as well as an F350 dually diesel. Put synthetic lube in it and leave it alone..
94 4Runner V6
88 Lincoln Town Car
90 Yugo GV+
Skulirag
My tercel:: 1986
Re: LSD Solution
Post by Skulirag »
So basically I could just get this:
https://www.ebay.com/itm/Car-LSD-Limite ... JS&vxp=mtr
JDNightFox
My tercel:: toyota
Re: LSD Solution
I wish their website actually posted the dimensions of them so I could compare what the difference is between the car versions
Re: LSD Solution
I do not understand, one of the website links goes to ebay and shows a convertsion kit for $18. the other a kit for $329.
are these the same, or similar convertion plates? do they come with the same parts?
$325 is a bit of a bite, though not bad to get some LSD action (though I suspect it is not as functional as a real costly LSD). but the same parts for $18, (knock off?) might be worth the effort to try it out, since you would not have much money into it.
Some one needs to try this out. I may have a extra diff to sacrifice to such an experiment.
JDNightFox
My tercel:: toyota
Re: LSD Solution
Petros wrote: Thu Nov 09, 2017 8:54 pm I do not understand, one of the website links goes to ebay and shows a convertsion kit for $18. the other a kit for $329.
I'm definitely going to get one but I need to know if the Toyota one on their website is the same dimensions as all the others
splatterdog
Re: LSD Solution
Post by splatterdog »
Back in the 80's Hotrod magazine put just the block and springs in an open Ford 9 inch. The pressure on the side gears was enough to lock it up to smoke both back tires on a mustang. Hard to say about long term durability. Probably beats welded spiders gears!
LowBuckCanuck
Re: LSD Solution
Post by LowBuckCanuck »
I found a knockoff one on Canadian amazon for 30 bucks... I would get it but have no idea how it works (?)
The way diffs work has always seemed like gearing wizardry...
I would be interested in putting this in the rear so I can use the 4wd on the street if need be.
LowBuckCanuck
Re: LSD Solution
Or are these kits only to make the front wheels lsd?
JDNightFox
My tercel:: toyota
Re: LSD Solution
These are for either but you still wouldn't be able to do 4wd on the street
