Thanks for the info! What about this spring that came from the back of the carb that closes the butterfly valve to the proper idle position after you let off the gas? It’s wrapped around the metal pieceThe Professor wrote: Tue Aug 20, 2019 9:17 amSomeone already answered your question in the other thread, but it's a one-way check valve. Can be replaced by a universal part.Shanemt wrote: Fri Aug 16, 2019 5:20 pm Can anyone tell me where I can get one of these filters and the rubber tubes that connect it?
Carburetor disassemble and assemble video
Re: Carburetor disassemble and assemble video
Is the float level chart the same for 83 and 87?
yes, it should be. there were a few minor changes to the emissions system, and the jetting, but the carbs are almost identical and the floats are all the same.
Thanks petros it worked pretty good, car is happy.
- My tercel:: 1988 stock auto
https://youtu.be/9UFgCyHWDns
the primary on mine looks strange
can anyone confirm that the fuel should dribble out not atomize?
