Brake Up-grades MR2 Parts Vented Rotors Corolla Spacer Figs
Re: Brake Up-grades MR2 Parts Vented Rotors Corolla Spacer Figs
The Professor wrote: Thu Jan 17, 2019 7:47 am Petros, on a cast iron rotor the hub area is just painted or e-coated, only two-piece brake rotors with an aluminum hat can be anodized anodized.
yup, I know that. did I imply I was unaware of that? I have actually assisted in selecting and installed such rotors on a $2 million racing programe for Nissan USA back when they had a racing program as part of their marketing campaign (1978-1985). I always thought those would be awesome on a street car, saves weight and improved cooling, but as I stated, very costly compared to the one piece iron rotors.
nerdsrule wrote: Wed Jan 16, 2019 4:17 pm I'm pumped to do this swap. This helps me have a solid plan. we'll see, maybe I can come across an mr2 booster and mc somewhere
it is a very worth while up grade, it will not disappoint. best place to the the first gen MR2 master and booster is at a wrecking yard. they show up regularly. You can also buy both the master and the booster new, they are available. but these are pretty pricey to buy new. perhaps they are not common to other cars and not produced in large numbers, neither are any more complex or very different from the standard Tercel or Corolla master and booster.
I would recommend to everyone on this forum to do this brake up grade when their current brakes need to be replaced. the calipers and rotors cost about the same, and it is hardly worth putting in the undersized factory brakes since it will likely just warp on a hard stop, or after a long down hill run. the rotors and caliper up grade can be done without changing the master and booster, and still get most of the benefit.
nerdsrule
My tercel:: NEW! '87 t4wd dlx, red. "slow red rocket", "Steve Turkel" in contential as names.
Post by nerdsrule »
Called six yards today- one actual said "wow, that old, huh?" There apparently is a conspiracy to scrap cars over 20 years in yards in VT. Rust and such. I may have found a Tercel, but I got anywhere from chuckles to laughs when I said "MR2."
teranfirbt
Post by teranfirbt »
Yeah, I've found it hard to find anything older than the mid 90's in the yards as well :\
Petros: What's the point of changing the master cylinder and booster? The Corolla front brakes I have a slightly bigger than the OEM brakes on my 1st gen MR2 and I don't really have a problem with the feel or force required...
the MR2 master has a smaller dia, improving the master to slave ratio and it will increase braking force to the wheels. the MR booster is slightly larger dia, and the later ones are double diaphragm. You need the booster to bolt it in the Tercel. the MR2 master will not bolt to the Tercel booster, but odly the MR2 booster fits perfectly to the Tercel firewall mount.
You do not strictly need the MR2 booster except that it felicitates mounting small dia master into the tercel
older cars seem to show up only in the self service wrecking yards. large traditional yards will not sell a lot of parts from older, less common cars, nor can they get premium prices for them. many of the self service yards will contract with professionals "parts pullers", you just need to find one. If you find an older car in a picknpull in another state you need parts from you can hire the local sercie to remove and ship your part to you. usually it saves money, but mostly it gets you parts for your car you can not get elsewhere.
Every time I notice an MR2 in a local yard I will go and pull the master and booster off of it. I usually sell it to another forum member to allow the conversion.
Iggzmon
My tercel:: '84 Truckcel 4wd
Post by Iggzmon »
Petros wrote: Sun Jan 20, 2019 5:37 pmEvery time I notice an MR2 in a local yard I will go and pull the master and booster off of it. I usually sell it to another forum member to allow the conversion.
Any chance you have another one for sale? I'm so excited to do your conversion on my Trukcel!!
I have to look and see what I have left, I have not been able to find any cheap mr2 master/booster/brakes for several years.
MrWrench
Post by MrWrench »
Thanks Photobucket for ruining this thread. Is there any chance you could re-upload the photos Petros?
Thanks!
1983 AV-II Sprinter Carib.
I have been planning to do this when I get some spare time, I would like to restor the original thread. I think I still have the original photos, from 11 years ago, that I can now be post directly into the forum.
Without the photos, the instruction should be all you need to do it, the pictures just give you a visual reference for first timers.
Post by irowiki »
If you right click, open picture in new tab you'll see the actual picture!
señor.tercel4wd
My tercel:: 1983 Toyota Tercel 4WD SR5
Post by señor.tercel4wd »
irowiki wrote: Wed Mar 11, 2020 5:14 pm If you right click, open picture in new tab you'll see the actual picture!
Those cheat codes though... Thanks man. I genuinely didn't know about that.
'83 Tercel SR5 Wagon Overland Build Thread >>> viewtopic.php?f=6&t=14880
MrWrench
Post by MrWrench »
Well, I just finished with mine. Car stops like brand new! I couldn't believe how much of an upgrade this is! I did notice I heard some on and off grinding when driving.
I decided to pop the wheels off when I got home and found what appears to be my Golf rotor rubbing on the outer inside of my new calipers on both sides.
Is there a reason for this? What should I do from here?
The caliper didn't slide on particularly the easiest. I had to tap it in some. But it bolted right up and everything functioned smoothly. Besides this wear, obviously.
Here is a few pictures and the parts list will be at the bottom. Thank you!
Parts list.
1986 TOYOTA MR2
OEM booster
CARDONE calipers
19-B1009
19-B1008
RAYBESTOS pads
EHT242H
ADVICS master cylinder
BMT115
New rubber lines on both sides
Rotors are from
1986 VOLKSWAGEN GOLF 1.8L L4
RAYBESTOS 9900R
since it only appears to rub on one side, perhaps the the off set on the rotor is incorrect to center on the caliper. or perhaps the rotor can be be turned down so it is thinner, and will not rub.
The Professor
Post by The Professor »
This is why I always hesitate to use parts from another manufacturer that "fit" but aren't identical, particularly for a safety-critical system like the brakes. However this modification seems to have been performed by at least a handful of members, and while that's a pitifully small sample size, I would expect the community would have already identified any incompatibilities by this point in time.
Is this happening on one side only, or both front brakes? First order of business is what Petros suggested; inspect and confirm that the parts are indeed identical L-to-R.
My first inclination would be to inspect the caliper. Make sure the slide pins are greased and aren't binding during operation, same with the piston.
Second thought is to inspect the wheel bearings for play.
Those wheel spacers also give me pause...
1975 Subaru SuperStar wagon
1987 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
