FOR SALE Tercel 4 WD parts
I have 2 re-maned axels LH and RH with less than 1000 miles on them, 40.00 ea plus freight, from rock auto. I also have a clutch and pressure plate from rock auto with 1000 miles on them, for 45.00, plus freight. All of these parts are in like new condition, they were in my 1984 4wd tercel thanks Larry
Re: FOR SALE Tercel 4 WD parts
bump up these pieces are still for sale
bump parts are now 50% off
Hey Larry,
Will the clutch and pressure plate work for a 4 ac engine as well (in my T4)? If so, I am interested.
those should fit fine, you should have your T4wd flywheel on your 4a engine, which is what the clutch bolts to.
Thanks Peter,
I thought that to be the case, but wanted to check.
- 4wdEconoBox
I kind of want the clutch and pressure plate!
