Anyways to the problem,
I've been doing all the usual things found in the faq plus some others but the car is persistently running hot in a weird way. If left to idle in the driveway the T-stat appears to open, fan cycles, thermometer is dead centre over the thermometer symbol/line. If I'm driving at highway speeds, it is also fine and holds dead centre. But, once I hit traffic or slow down, it climbs up to about 3/4 of the way towards red or even a bit higher. Strangely, if I sit in traffic long enough it starts to cool again, but once I get to even 60km/h and then back down to idle/traffic it spikes. It has never touched the white line or had a catastrophic overheat but of course I'm concerned as this is winter in Vancouver and I'm hoping to take her down the coast to LA this summer.
What I've done already:
- Flushed the coolant and changed the t-stat (high quality, OEM) first, about a month ago. It definitely ran cooler after this but only when idling/at highway speeds.
- Set the timing to 10BTDC (ran much smoother, minor difference to overheating problem)
- A month after the first flush I replaced the water pump as it was leaking and while it was open I checked the thermostat on the stove with a thermometer in the water and it worked well - opened @ 180 F
- Decided to replace the radiator with a nice double wall/thick one as the old one was held together by rust
- Replaced upper and lower rad hoses
- Used some prestone radiator flush, flushed for 30 mins, drained and then filled with new coolant (again).
Last 4 points were done yesterday. I've been watching for bubbles to work their way out but I wasn't sure if airlock alone would cause this ongoing problem.
Other info
- The fan works when sitting idle as I mentioned, and if I pull the plug on the sensor it turns on immediately.
- I've noticed that when it's running hot if I pull over the fan will be off and the bottom hose only luke warm which seems like the T-stat. But if I idle long enough it will begin to operate normally after a few minutes.
As I type this out I'm thinking 'god damnit I hope it's not just the T-stat and I wrote all this extra info for nothing'
Any suggestions?
