Parts parts parts
Re: Parts parts parts
Hey Dan!
Do you have the piece of dash that sits below the steering wheel?
- My tercel:: 1983 SR5 4x4 with a tummy tuck and a nose job and now a pace maker!
The big piece or the colum pladtic
I used to laugh at the man with a pinto
, until I became a humble servicer of a tercel ![Neutral :|](./images/smilies/icon_neutral.gif)
![Laughing :lol:](./images/smilies/icon_lol.gif)
- Gottolovem
Standard column or tilt?
I am looking for a front left turn signal lens. Do you have one of those for a 84 tercel SR5?
- Gottolovem
Probably I'll get back to yaelmonteek wrote:I am looking for a front left turn signal lens. Do you have one of those for a 84 tercel SR5?
![Old Geek. :oldgeek:](./images/smilies/icon_e_ugeek.gif)
the actual turn signal is below the bumper, it is rectangular, amber and usually pretty well protected except damage from stones kicked up by traffic. There are a pair of left and right marker lights outboard of the head lights, often people call these turn signals, but these are the marker lights. These lights tend to get damaged because they are exposed on the corners of the car.elmonteek wrote:I am looking for a front left turn signal lens. Do you have one of those for a 84 tercel SR5?
do you still need an aircleaner assembly? I ran across two spares in my garage, you are welcome to one if you still need it.Clhall1993 wrote:Looking for a air cleaner still got it
- NickC809
- My tercel:: 1985 T4WD
I'm looking for as many 2 port vacuum advances as possible, do you have any?
- My tercel:: 1983 Toyota TRDcel base model
Alright this will be a long shot but I'm looking for the part in the transmission that the shifter ball sits in. It's the cast iron "arm" that connects to the main selector rod inside the extension housing.
Mine somehow rusted so bad that the shifter ball has a ton of play in there.
Another long shot but I'm also looking for a driveshaft with good u joints. Looking for the front section with the carrier bearing.
Thanks!!!
Thanks!!!
Petros wrote:the actual turn signal is below the bumper, it is rectangular, amber and usually pretty well protected except damage from stones kicked up by traffic. There are a pair of left and right marker lights outboard of the head lights, often people call these turn signals, but these are the marker lights. These lights tend to get damaged because they are exposed on the corners of the car.elmonteek wrote:I am looking for a front left turn signal lens. Do you have one of those for a 84 tercel SR5?
Yes, I need the Left indicator. part number 16-44L I have a 84 AWD tercel SR5
- Gottolovem
I likely have that tranny part can you send me a photo?Steve o 77 wrote:Alright this will be a long shot but I'm looking for the part in the transmission that the shifter ball sits in. It's the cast iron "arm" that connects to the main selector rod inside the extension housing.
Thanks!!!
It's the cast iron arm that is being removed in these screenshots. Sorry I live 40 miles away from my garage right now so I can't take a pic.Gottolovem wrote:I likely have that tranny part can you send me a photo?Steve o 77 wrote:Alright this will be a long shot but I'm looking for the part in the transmission that the shifter ball sits in. It's the cast iron "arm" that connects to the main selector rod inside the extension housing.
Thanks!!!
I have one for cost of shipping
- helipilot77
- My tercel:: 1984 SR5 wagon
Are you sure you don't just need the bushing that goes over the ball?Steve o 77 wrote:Alright this will be a long shot but I'm looking for the part in the transmission that the shifter ball sits in. It's the cast iron "arm" that connects to the main selector rod inside the extension housing.
Thanks!!!
. / TOYOTA
./_| |/|/ |]
./_| |/|/ |]
