I got a U.B.W. UNIDENTIFIED BROKEN WIRE
- My tercel:: 1983 SR5 4x4 with a tummy tuck and a nose job and now a pace maker!
I used to laugh at the man with a pinto , until I became a humble servicer of a tercel
Re: I got a U.B.W. UNIDENTIFIED BROKEN WIRE
that is not a connector, but a wire splice joint. the wire does not look like part of the stock wire bundle, either a replacment or perhaps something added by a previous owner to power up an accessory, or to by-pass a bad section of wire. You will have to trace where it goes.
It goes into a harness that goes to fuse box under hood. And the blue thing is a butt connector
What I mean is the wire leads to the fuse block
- My tercel:: 85 Tercel 5dr FWD
It was probably a wire that a previous owner added to operate an aftermarket accessory of some sort. Are you having an issue that you think is caused by this wire? If not, I would just leave it alone.
1985 Tercel 5dr Hatchback
2003 Chevy Suburban
2014 Ford Flex
2003 Chevy Suburban
2014 Ford Flex
I'm thinkING it might have something to do with the fan not comming on but I don't know where it goes
- lannvouivre
It may be one of the ones that goes to the transmission. Is this on a manual? I think the wires going to the trans are for the 4WD indicator and something else. Is the wire also kinda fat, as in not the usual 18 gauge?
Why yes it is of the more rigid style when compared to the thinkness of the others within its realm.all the 3 wires that go to tranny cluster are fairly thin .at least that is how they were when I found that my assistant (who I blame when things are forgotten are hooked up wrong )did not plug in the aforementioned cluster and we're slowly ground off one hop and scrape at a time
