Clicking noise when i 3rd and 4th gear and...
Re: Clicking noise when i 3rd and 4th gear and...
Gottolovem wrote:
I'm a really nice guy :mrgreen:
Can confirm. He even looks like this: :oldgeek:
gnarnold
My tercel:: 1983 SR5 4x4 with a tummy tuck and a nose job and now a pace maker!
Post by gnarnold »
Ohhhhh kay???
I'm not sure what you mean by all that when I think it was you that helped me via this Web site .just pontificating .
Now what is the minimum crap I have to remove to get the axles to where the need then
I know your a nice guy .just like you know I don't rip people off
I used to laugh at the man with a pinto :lol: , until I became a humble servicer of a tercel :|
gnarnold
Post by gnarnold »
But seriously guys I gotta go to work
Gottolovem
Post by Gottolovem »
Removing the rear axles is part of this video start's at minute 3 yours will likely pop out easier.
You will only need to pull both axles out about 6 inches not all the way out.
viewtopic.php?f=7&t=10503#p77871
1) jack up the back of the car and put it on jack stands,
2)remove the wheels,
3) remove the brake drums (parking brake off!),
4) unbolt the backing plate through the axle flange (four 12mm nuts), these hold both the brake backing plate and the axle retainer in place.
5) Than you can pull the axle straight out, they only need to come out about 6", but be careful you do not damage the seal by allowing the axle shaft to rub on them. I hang the end of the axle on a bungy cord to suspend it off the seal.
sometimes you need to use a slide hammer to pull the axles if they have not been removed recently, I have found this is not usually necessary, I pound on the axle flange with a big plastic hammer sideways and outward (as much as the angle will allow) and usually get it to wiggle out.
You do not have to remove the brakes, they just stay in place. And than you can pull the diff assembly/third member out.
while the axles are out you can inspect the axle seal, and roll the wheel bearings with your hands to feel the condition of the wheel bearigns (should be smooth). If you need a seal or wheel bearing, now is the time to replace those too.
rer233
My tercel:: Multiple
Post by rer233 »
PS
I can vouch for that!
An old buddy of mine told me years ago the attitude at his workplace was "There's never time to do it right, but always time to do it over." Pull the axles and be done with it.
gnarnold
Post by gnarnold »
Well the conclusion to this chapter in the tenth volume 7 series is ......
Mutha scratching son of a birch tree gad nabbin thing STILL leaks .to hell with it all
I really do not like the qualities of gear oil.nor do I enjoy the essence.
gnarnold
Post by gnarnold »
well I went to gear oil gasket maker and she's hurt pretty good but doesn't seem like its leaking from that part any more it seems like its leaking from the part of the propeller shaft meet up with the differential yolk the part that turns the pinion gears the gears I got to go out of town I got to drive 50 mIles .wiki make it
just keep topping up the diff gear oil.
gnarnold
Post by gnarnold »
Timing issue resolved driving with plugged dizzy vacuum lines disconnected choke runs great at 900 rpm via stock tach in instrument panel .
Well like a little brat starving for attention she had to sacrifice something ,. And she put forth her only begotten starter.not even two months old .chews em up and spits them out .she is alive and she is pissed ..........at me for some reason .I only spend countless hours and all my spare cash in hopes of no problems no manic episodes no raging fits of powerlessness followed by half hearted attempts of reconciliation. She is a bitch and she knows it.she takes pride in the fact. I'm starting to think a seperaton is the best thing .before some one gets hurt.
gnarnold
Post by gnarnold »
Petros wrote:.hose things happen sometimes". in frustration the owner takes it out on the car, and than junks it. Every body panel had ax holes in it, every window smashed out of it
Oh I go to that place in my head where I have to tell myself ......no you are not going to ghost ride this car off a very high cliff .or into a wall . That will not fix the car .only make it worse .then I started swearing at the car .now it's mad at me again .
