my home made alum rim straightener
had a lot of people ask me to straighten their bent rims for them, put this together and it works really well. little heat and a little jacking, can get them back 90% sometimes better depending on the make of rim.
Re: my home made alum rim straightener
Very impressive. How is it mounted in the hub?
the large shaft you see stickin out has tapered collars on both sides like a wheel balancer, then it steps down to 1-1/2 shaft that goes through 2 bearings with a 1"nc thread to pull it up tight and lets you spin the wheel
Where did you get the parts to make it?
i own a machine shop so just stuff i had kicking around
that's awesome, jimcrazy. makes it look so simple.
most of the time takes 20-25 mins to do one
Nice, I would love to have that stuff to make my own wheel balancer.
