Rough idle
- My tercel:: 1987 Toyota Tercel SR5
Rough idle
Hi everyone, I have a quick question, what would cause an 87 sr5 to have a a rough idle and then just die, I've checked for vacuum leaks and didn't find anything. What would be my next option? Tune-up?
Re: Rough idle
Have you actually adjusted the idle? Does it do it hot, or cold? When is the last time the plugs, wires, rotor and distributor cap were changed?
Re: Rough idle
We'll I just bought the car so I'm clueless on this lol and he told me that he changed the distributor, cap and rotor, and spark plugs. And it does it all the time, Im not sure though on the temp, I'm from Missouri lol
Re: Rough idle
I mean engine cold or warmed up.
Re: Rough idle
welcome to the forum, twamble.
check the FAQ, #6 and #7.
https://tercel4wd.com/forums/viewtopic.php?f=2&t=7442
Re: Rough idle
It does it when the motor is warm
Re: Rough idle
welcome to the form,
short of tracking down a vac leak, you might try speeding up the idle a little. also, use the vacuum routing diagram and double check that all the vac lines are connected to the correct places, and none are cracked or damaged. This is easy to do with the vac diagram, it will only take about 15 to 20 min to check them all, just take one at a time and verify it is routed correctly. Do not assume who ever worked on it before, including a repair shop, got them all installed properly.
Re: Rough idle
Okay lol and thanks I'll probably comment back on this if it keeps doing what it's doing
Re: Rough idle
So I checked again for any vac leaks and didn't find any, what do I do now? Suggestions?
Re: Rough idle
did you read the FAQs i linked to?
- canoeontheriver
- My tercel:: 1983 SR5 4wd Wagon
Re: Rough idle
Do the simple things first...if cap was replaced make sure plug wires are in correct order and connected well.
A Human Being on the path of Life, Truth, and Love.
Re: Rough idle
is the large vac line on driverside base of the carb plugged into the bottom of the air filter housing?
when the air filter housing is removed you need to plug the end of that hose so you can run the engine with air filter housing off (for testing and inspection purposes)
bad idle can be caused by quite a few things
sometimes its the carb itself
