Or if your existing "broken"transmission still has a good diff in the front of it still you can change it out to the replacement tranny ?marlinh wrote:You will need the rear pumpkin from that 83 to match the front diff of that trans. The gearing is not compatible with your car.
As to a fair price I personally would not pay more than 3 to 4 hundred! Less if i had to pull it myself.
Be sure to check the tranny before you pay for it! After you pull it and it's on the ground select each gear and turn the input shaft by hand to verify the gears are turning the front diff at the same time CHECK ALL GEARS 1 THROUGH 5 INCLUDING REVERSE if they all spin the diff it's likley a good one
good luck
