eBay "carrier assembly" from 1983-84 T4WD
- garyfish
EDIT: I changed the subject line because the tranny is no longer available... but several "carrier assemblies" are (see post on 3/7/14, below)
http://www.ebay.com/itm/TRANSMISSION-AS ... ef&vxp=mtr
$450 + freight for the tranny, located near Santa Barbara, CA
seller also has two auctions for a "Carrier Assembly" to fit a 1984 T4WD -- $200 each + freight
I assume a "carrier assembly" is the same as a rear differential??
http://www.ebay.com/itm/CARRIER-ASSEMBL ... 2a381a8857
http://www.ebay.com/itm/CARRIER-ASSEMBL ... 07&vxp=mtr
- Gottolovem
Re: eBay manual tranny ++ from '84 T4WD w/ 89K (SoCal)
Haha Carrier assembly it's been years since I've heard that
Sounds like the seller is aware that the rear must match the transaxle.
For me "carrier assembly" is a complete rear axle.
- My tercel:: None
Steelhead recyclers. They're out in Goleta, CA. I visited their yard once. Some stuff was a little overpriced.
2015 Honda Fit EX "Malachi"
the "carrier assembly" might just be the word they are using for the third member, the part that carries the ring and pinion, bearings, and the input shaft seal.
- garyfish
just checked eBay... none of the 3 auction links listed in the first post are currently active
on a whim, I did an eBay search for "carrier assembly tercel" and, surprisingly, several results came up:
83 84 TERCEL CARRIER ASSEMBLY FRONT AXLE MT 4WD 6 SPEED
$175, free shipping
http://www.ebay.com/itm/83-84-TERCEL-CA ... fd&vxp=mtr
83 84 TERCEL CARRIER ASSEMBLY REAR AXLE 3.73 RATIO
$250, free shipping
http://www.ebay.com/itm/83-84-TERCEL-CA ... b4&vxp=mtr
$100 + shipping from Port Angeles, WA
http://www.ebay.com/itm/83-84-TERCEL-CA ... b5&vxp=mtr
CARRIER ASSEMBLY TOYOTA TERCEL 1984
$200 + freight from SoCal
http://www.ebay.com/itm/CARRIER-ASSEMBL ... 0c&vxp=mtr
$175, free shipping
$250, free shipping
- Gottolovem
Re: eBay "carrier assembly" from 1983-84 T4WD
Front assembly ??? must be the bell housing with diff.
I wonder if they get that much $ i would almost give one away to keep a car on the road.
- My tercel:: 1983 SR5 4x4 with a tummy tuck and a nose job and now a pace maker!
Give one away??????!!!!!
I used to laugh at the man with a pinto , until I became a humble servicer of a tercel
- Gottolovem
You figure out what you need first then we will talk
- Gottolovem
Yes the big one and the one on the other side you can't see in the photo.
If your car is 1983 it is probably 3.73 but I want you to confirm this first
- Gottolovem
Well it's 4.1 as far as I can tell it's awfully hard to count the little back Gear on account that there are so many missing teeth
May want to count the rear diff to be sure
95 Camry Wagon, 170k
97 4runner, 275k
97 4runner, 275k
All counted and I do honestly believe in my hard earned REPRIEVE! ! THIS COULD BE WHAT THEY MEAN WHEN THEY SAY GOOD THINGS HAPPEN WHEN YOU HIT YOUR 40'S
Thank the Lord above ! I promise no more taking sports cars off the line anymore . no more 75- 80 mph from here to Temecula.
