transmission
- Gottolovem
Re: transmission
I think I understand now but still want to see a photo of broken part.
I'm sure someone will have a dif/bell housing in there extra parts.
- My tercel:: 83 Toyota Tercel 4WD SR5,85 Toyota Tercel 4wd SR5,86 Toyota Tercel 4wd SR5 complete for parts,81Toyota tercel SR5 liftback old school
Re: transmission
thank you much for help i like to see this little toy running but takes time ,the parts special for transmission assembly become hard to find
Re: transmission
i just put some pictures so you guys can see what i have wrong regarding the tranny problem its that piece looks like a big bell .those internal parts they not in good shape,bad teeths
Re: transmission
the one in a bucket is good working order they sad
- Gottolovem
Re: transmission
The last photo(the one in the bucket) is the transmission if it is still good all that you need to fix your car is the bell housing with the diff gears in the second photo.
That should be much easier to find than an entire transmission.
I might even have one.
Re: transmission
well sounds like a good news,thank you has to be 4 10 gear ratio or this part doesnt count the gear ratio
Re: transmission
if you can see that circle pinion the teeth arrund it they gone on a small area ,so that cause the problem i think call ring-pinion,spyder gear ,bearing set ,this is what they tell my at the shop is wrong in that bell housing or front diff whatever that name is,
- Gottolovem
Re: transmission
I will look to see if i have one when I get home.
Do you know if the previous owner ever did any transmission work to the car before you bought it?
I ask because they may have put the wrong gear in the car.
If you go look at the edge of the broken gear there is a stamp that says 4.11
Never trust what the last guy did to your car
Re: transmission
i dont think soo ,the guy who i purchase this tercel he is not onnest person ,he sad this car has nothing wrong exempt the front right axle,when i got home from spokane WA,i went purchase a front axle right side from oreally ,replace then still problem bad clink when i drive test the car ,so i take it on trailler at toyota shop here where i live in Boise Idaho and the mechanic sad you have this part of transmission bad,front diff so this how i find out ,he doesnt spent monney for maintanance that guy who i purchase from,i go see the stamp now at my garage ,i let you know Thanks much Gottolovem
Re: transmission
10 teeth on pinion (small gear) is 4:1
11 teeth " " 3.73
11 teeth " " 3.73
Re: transmission
i count the teeth on that ring they are 41 total so been a 85 with no modification looks 4 10 gear ratio to me if i am right
Re: transmission
hey Xirdneh ,want to say hello ,i remember you want to help me also before,thanks much i dont forget
- Gottolovem
Re: transmission
There is a stamp on the edge of the gear
no need to count them
Re: transmission
Gottolovem you absolutly right there is a small circle at the edge with #41 inside that stamp 41
