Blue 194 LED's
EliRush
My tercel:: 1986 4WD Wagon
Re: Blue 194 LED's
Post by EliRush »
That is exactly why I changed them. The white LEDs would look fine by themselves, but with the headlights on they seemed blue. The headlights put out a yellow light, so even though technically the LED was pure white, they seemed blue...and I don't wanna line any pockets downtown.
These amber LEDs are ok, but I keep thinking they will be brighter than they are. I may have to go with an SMD panel to get the effect I am looking for.
1986 T4WD SR5 in Beater Blue
toughtercel
Re: Blue 194 LED's
Post by toughtercel »
EliRush wrote:I just put these into the front parking lights, and I can get a picture if anyone is interested. I had true whites in there, but it looked blue at night.
Hey that what I'm looking for, I current have Orange 194 at front running light beside the head light , I had them since 1999 and trying to get them brighter as "FOG LIGHT" , where can I get them .
I shouldn't worry about the federal law now because all those new car's light are extremely bright and they are factory too , even the Local buses too.
toughtercel
Re: Blue 194 LED's
Well I bought a pair of 194 Orange LED as for running light , if they are very powerful then I might add independent switch as "Fog light "
toughtercel
Re: Blue 194 LED's
well I got the Orange 194 LED light for front running light , It little bright but it only shoot one spot so I am order another brand of Orange 194 LED which I hope it will shine all over the place like "fog light "
EliRush
Re: Blue 194 LED's
Post by EliRush »
I had the same thought, toughtercel. A few times, apparently. :) I have rigged a 1157 tail light LED into a 194 base, but it still isn't bright enough for real fogs.
Maybe one like http://www.ebay.com/itm/251039240474 would be strong enough, but heat could be a problem.
I am content with the standard yellow 194 SMDs. Anything I have that is brighter is pure white.
toughtercel
Re: Blue 194 LED's
http://www.ebay.com/itm/220842211427 , just type (TWO Orange AMBER T10 168 2825 194 W5W 6-LED Lights) on E-BAY ,it will show several brands of light bulbs , they are expensive but interest to see how they works .
4doorVIP
My tercel:: 1988 SR5 Wagon
Re: Blue 194 LED's
Post by 4doorVIP »
I just ordered these guys, over kill on the amount but I have a couple cars to do this with
http://www.ebay.com/itm/170819876815?it ... 60&vxp=mtr
and
http://www.ebay.com/itm/230669048292?it ... 60&vxp=mtr
2JZGTE-powered Tercel SR5
JesseN
My tercel:: 1986 2WD DLX Wagon
Red 194 LED's
Post by JesseN »
So I received and installed my RED surface mount 194 based LED's today. The only downside is no brightness control, either on or off. They may be a little too bright for me. I am going on a test drive in a few minutes. I can't wait to get a cluster with a tach built in, I like the look of the fuel gauges better.
Jesse
Re: Blue 194 LED's
Could easily add your own dimmer, assuming they can take a lower voltage. Or rig them up to the parking light circuit?
Re: Blue 194 LED's
my LED flash light goes dim as the batteries wear, no reason a dimmer will not work on the dash LEDs. If your car does not have a dimmer you can always put some translucent tape or plastic over the lights when you install them to reduce the amount of light they put out.
JesseN
Red 194 LED's
Post by JesseN »
Petros wrote:my LED flash light goes dim as the batteries wear, no reason a dimmer will not work on the dash LEDs. If your car does not have a dimmer you can always put some translucent tape or plastic over the lights when you install them to reduce the amount of light they put out.
Here is the night shot. When I turn down my dimmer knob the brightness stays constant until I get to the very end and then they shut off. I would probably have to get a different potentiometer? But I think the brightness is livable for now. It's actually my new Tach that I will probably end up hating 8)
Re: Blue 194 LED's
what you might try doing is finding some red light condoms, as opposed to the green ones that come stock on our cars, and stick those over the stock bulbs. then you would have the red dash cluster but you'd be able to control the brightness. i can't remember where i read about people finding the red light condoms but i think they're pretty common to BMWs or audis.
Re: Red 194 LED's
JesseN wrote: Here is the night shot. When I turn down my dimmer knob the brightness stays constant until I get to the very end and then they shut off. I would probably have to get a different potentiometer? But I think the brightness is livable for now. It's actually my new Tach that I will probably end up hating 8)
I do not know much about how the LED responds to power input, I seem to remember my electrical engineer brother saying they stay constant because the draw so little power, but than I have also had the experience with batteries running low and seeing them go dim. Perhaps that is because the voltage drops, not the amps. I suspect the dimmer in the car may drop amps to the lights, not voltage, which would stay constant.
For your tach, there is always the old standby; black tape on the face of it. If you wanted to open it up and just pull the plug on the digital display that would solve that, but black tape is the more reliable approach, and no risk of harming the electronics. sometimes the simple solution is the best.
drege
My tercel:: Hadatercel
Re: Blue 194 LED's
Post by drege »
Know this is an old thread, but I wondered about the dimming capabilities too as I started reading.
As I understand LED does draw like 10% of incandescent but can operate on dimable systems but the dimmer needs to be digital not analogue, like the dimmer knob is just a high resistance coil and two zone contact, I'm sure there is aftermarket units available, new cars have LED gauges and are most likely dimable (I've not had too much time to play with new cars.)
Here it is! http://www.amazon.com/Lighting-Controll ... mer+switch
drege
Re: Blue 194 LED's
Post by drege »
Still thinking about the LED overhaul, anyone ever find the itsy bitsy bulbs for the lighted controls?
Are they the #74 bulbs like this?
https://www.superbrightleds.com/moreinf ... -base/226/
3/16x3/4 sounds about right
I don't know if I'd bother to swap the air conditioner button bulb or not but if Someone knew if there was a right and left bulb on the speedometer to do something like this, I'd do it too.
