I didn't want to alter the car or the MB engine shock, as I wanted to be able to replace the engine shock if needed. so I built this adapter
I cut a tube about 1.25 inches long, on top of that I piut a 17mm nut, so i'd have something to hold on to while installing the adapter. then I welded in the little tiny 10mm nut that threads onto the end of then engine shock, on top of that I welded a nother random nut so there was space on ether side of the nut that was actully doing the threading into the shock. I then chased the 10mm nut wuth a tap because of the hear warp. On top of that stack I welded the rod I cut off the toyota shock.
This allows the adapter to thread into the shock and get tightened down to the shock with the 17mm nut. then its just like installing the toyota shock.
Added bonus, the MB engine shock has the same threads as the Toyota shock, and all the rubber bits and washers fit from ether application.
