Complete listing of 4 bolt x 100mm rims
- GLet71
- My tercel:: '87 6-spd SR5 4wd Wagon
I have found a fairly established list of 4x100mm bolt pattern rims from a site if you're looking to upgrade. Let me know if you recognize any errors in the list so we can pull 'em pronto. I made a PDF, but it won't let me upload it, so you're stuck with jpg's, sorry!
http://www.roadkillcustoms.com/hot-rods ... readMM=100
Re: Looking for some rims, are ya?
NIIIIIIIIIIIIIICCCCCCCEEEEEEEEEEEEEEEE
glet71 getting down to business on the forum! i smell another 'sticky' coming.
- GLet71
Things to do while sulking about not making the PNW meet, David!
There is a really sweet deal on a set of Ford Focus 14" rims with new winter tires, and I wanted to see whether they would work or not. Well, not. Up until now I have been using Petros post from this thread: https://tercel4wd.com/forums/viewtopic.php? ... it=14+rims
He mentioned he had pulled the info from a few different sources, so I wanted to see what I am really eligible to use. Hope it works!
Currently:
Formerly:
Formerly:
I concur - and thou art just SO prescient!dlb wrote:! i smell another 'sticky' coming.
- My tercel:: 1986 SR5
Re: Complete listing of 4 bolt x 100mm rims
Tried putting my 4x100 Aspire rims on my T4, but the center bore is just slightly too small. So that's something to watch out for when getting wheels. Generally aftermarket wheels will fit, because the manufacturer wants them to accommodate many different cars with the same bolt pattern.
Hello,
I just got a set off rims and new studded tires off a 1986 Honda Civic,155/80r13's. Civc's are not listed. Offset appears to be similar to a Tercel. Are these tires too small and should the rims bolt on?
Now that I read a few posts, it is likely that the center holes in the Honda Civic rims are too small....
100 mm.
1992-74 AUDI - Fox
1987-79 4000 FWD, including Coupe
1990-82 BMW - 300 Series
1987-85 CHEVROLET - Nova
1980-76 Chevette
1985-84 CHRYSLER - Laser
1985-82 Le Baron "K", New Yorker
1996-95 DODGE - Neon
1996-94 Colt
1990-78 Omni, 024
1986-82 Charger 2.2
1985-84 Caravan
1985-82 400 "K", 600
1985-81 Aries, Aries America
1984-81 Rampage
1984 Daytona
1999-95 FORD - Aspire
1998-90 Escort, EXP
1998-89 GEO - Prizm
2000-84 HONDA - Civic
1989-82 Accord
1991-87 Prelude
1999-95 KAI - Sephia
1994-90 MAZDA - 323, GLC
1999-90 Miata, MX-3, MX-5, Protégé
1999-90 MERCURY - Tracer
1999-94 MITSUBISHI - Mirage
1999-86 NISSAN - Sentra, Sunny
1991 B310, Pulsar
1982-76 OPEL - All
1990-78 PLYMOUTH - Horizon, Horizon AM, TC3, Turismo
1996-95 Neon
1985-84 Voyager
1985-81 Reliant, Reliant America
1998-91 SATURN - All
1999-96 SUZUKI - Baleno, Esteem
1999-92 TOYOTA - Paseo
1996-83 Corolla, Tercel
1992-80 Celica
1997-95 VOLKSWAGEN - Cabrio
1997-85 Golf, Jetta
1996-83 Passat
1995-88 Corrado
1994-85 Cabriolet
1994-83 Fox
1989-75 Rabbit
1989-80 Scirocco
1986-75 Dasher
1985-80 Pickup
1992-74 AUDI - Fox
1980-76 Chevette
1996-94 Colt
1990-78 Omni, 024
1986-82 Charger 2.2
1985-84 Caravan
1984-81 Rampage
1984 Daytona
1998-90 Escort, EXP
1998-89 GEO - Prizm
1989-82 Accord
1991-87 Prelude
1991 B310, Pulsar
1982-76 OPEL - All
1996-95 Neon
1985-84 Voyager
1992-80 Celica
1997-85 Golf, Jetta
1996-83 Passat
1995-88 Corrado
1994-85 Cabriolet
1994-83 Fox
1989-75 Rabbit
1989-80 Scirocco
1986-75 Dasher
1985-80 Pickup
you can add 2007 yaris 15" rims they fit but stick out a little
civics are on there, page 3. they're listed first by make, then model.
Thanks, found it. Looks like they'll fit and save me mounting and balancing. I wonder what the stock tire size should be for the Tercel. The tires off the Honda are 155/80r13. These are indeed very narrow.
83-96' Tercels come stock with 155/80r13's or there abouts, so I'm in luck there as well. Narrow is good for traction in snow.
dlx tercs came with 155/80r13, sr5's came with 175/70r13.
- BaileySims
II've got a question. Granted everything posted here will fit on the terc, I'm not so sure on how they will fit mine. I found a set of aftermarket 4x100 15x7 that I really want to buy. Only problem is that I'd have to buy them online and I'm not entirely sure they will fit. They have a bigger hub bore but I've read about the hub centric spacers helping with that, but if I put on the spacers, how do I know what offset I need in order for it to be able to fit under the fender?
WAGON MAFIA.
Blood, sweat and beers.
i can't answer your question about offset but i did recently learn that hub centric rings are not necessary. here's a quote from a guy on the corolla forum:
I raced with non-hub centric wheels. Just slowly tighten the lugs while unloaded, to allow the taper on the nuts to align the wheel and apply a liberal amount of anti-seize between rotor and wheel to allow slip. It usually takes me 6 rounds of tightening to get it proper. finger tight, ratchet until stop, ratchet until stop, torque, torque, drive for a while and re-torque.
and here's a link to some more good info on hub centric rings:
http://thesquealingtire.com/hub-centric-rings-defined/
