List of what I have done so far:
New diff fluid ( Tranny fuild is in garage have not gotten to it yet )
Valve adjustment
Newly painted valve cover and replaced cover seal
New brakes and brake lines all around ( new rotors and drums, new shoes and pads, new hardware, new wheel cyl.
New brake master cylinder
New 02 sensor
New EGR valve
New air filter
New vacuum lines ( over 30' of them)
New fuel filter
New front axles
New head lights
New bulbs for entire car
New catalytic converter
New oil filter
Replaced front main seal, cam seal, timing belt 200,000 miles
new paint job ( Almond satin rustoleum) looks great I masked everything and it looks good, should go great with mud.
It runs ok, was running great, needing a tune right now, either timing belt off a tooth or some carb adjustment problem, I hit 65 mph no problem, drive it around all day, no smoke, runs clean, miss firing though, and stalls out when you stop. I almost got it perfect, but would rather buy another honda....
Payed $900.00 for car put a lot into it and a lot of time, as you can see, make me an offer. Phadyd@gmail.com or text/call 707-228-2380 for pictures.
Thanks for looking ~ Krunk
NorCal 83 SR5 4WD wagon.
- My tercel:: 83 Toyota Tercel 4WD SR5 6 speed
I told my wife the other day "Men will always buy a car/truck, spend more money on it then its worth(loving every minute of it) and then sell it for less then they spent on it, ITS WHAT WE DO!" There is nothing you can do.
