Spring Compressor
Look around here for some great advice on getting the most out of your tools! Tips and tricks!
SynthDesign
Spring Compressor
Post by SynthDesign » Sat Dec 25, 2010 9:46 am
Coolest tool in a long time for me. I did the math after the last spring compressor failed and an ER trip was much more than the cost of this tool. And free shipping!
http://www.maxtool.com/us/products/ME4098.asp
Spring Compressor
I had to remove the return spring from the ram but I get about 170mm out of it now instead of the four inches it came stock.
85 Toyota MR2 (Blu)
86 Toyota Tercel 4WD DLX for sale (BluBoy)
86 Toyota Tercel SR5 Canadian Import (Galena)
83 Mazda RX-7 Mariah Widebody
Wait I have more
Re: Spring Compressor
Post by ARCHINSTL » Sat Dec 25, 2010 11:10 am
I'm glad this wasn't around when I did Golde's back in '07. I bought the HF clamshell for $30. I would have been sore tempted towards this one.
Were you kidding about the trip to the ER - from suicide sticks, I presume?
SynthDesign
Post by SynthDesign » Sat Dec 25, 2010 3:03 pm
I've had the harbor freight units fail on me multiple times. There was a very close call last time and I was lucky to only have my hand pinned to car. I said the next time I'd go at it with the proper tool instead of stupidity. Plus this thing only takes a matter of seconds to operate and at this point, time and safety are worth the money.
85 Toyota MR2 (Blu)
Wait I have more
Post by ARCHINSTL » Sun Dec 26, 2010 1:52 am
Since you mention HF units, I presume you mean the suicide sticks and not the clamshell, right?
The clamshell worked just fine, if a bit village-blacksmithy.
Post by takza » Sun Dec 26, 2010 6:11 am
I've got the cheapy HF unit....
http://www.harborfreight.com/catalogsea ... compressor
http://www.harborfreight.com/macpherson ... 0.html?p=1
I used mine 1X on 1 spring....did lube the threads and tried to stay away from the ends of the spring. Chinese stuff seems to usually have poorly hardened or heat treated metal parts...using low grade steel and fasteners?
There is an issue with an hydraulic compressor? I've had a Sears trolley jack drop suddenly after it ran low on jack fluid...would want to keep the fluid level topped up?
One of the reviewers bought 2 sets of these and used 3 per spring for added safety.
SynthDesign
Post by SynthDesign » Sun May 22, 2011 2:41 pm
This tool has sooooo paid for itself already! I made $80 at pick and pull just helping a few people pull springs off domestic vehicles today. In less than a dozen uses the tool is paid off plus some.
Side note, if you pick it up, grad an extra 1 liter bottle of hydraulic fluid as it leaks a bit during storage and transportation. I topped mine off this morning just to be safe.
85 Toyota MR2 (Blu)
Wait I have more
SynthDesign
Post by SynthDesign » Sat Jul 16, 2011 11:03 am
OH SNAP!
Just checked
It's on sale for $50 less than I bought it for, $129.99 and free shipping.
85 Toyota MR2 (Blu)
Wait I have more
