Went to Rock Auto and they have 2 different springs, Husky and Raybestus. I bought the Raybestus front and rear....only a few left. Part #'s are 5911068 for rear, and 5871055 for front. I just hope these numbers are correct
FRONT:
Inside dia. = 4.68 in.
Bar dia. = 0.5 in.
Free height = 15.68 in.
Spring rate = 100.5 lbs/in.
Load = 570 lbs
Load height = 10 in.
REAR:
Inside dia. = conical
Bar dia. = 0.485 in.
Free height = 12.61 in.
Spring rate = 122 lbs/in.
Load = 318 lbs
The fronts are correct, but the REAR specs are NOT correct for the 4wd tercel. WAY to short and not conical. Raybestus still hasn't replied to my questions...go figure.
I purchased the springs based on someone elses information without verifying for myself....oh well.
going to order these but in the 1200 lb.
http://www.tercel4wd.com/forums/viewtop ... 10&start=0
The fronts I bought are identical to the ones that were on. Just for giggles we put the old strut in a vise and took the end nut off just to see what kind of tension it had......It flew apart.......for about 5 feet, thats it. Now the new spring was a different story, really difficult to compress. We forgot the bump stop on the first one. Went to the second strut, and I was like what is this? Wait, the other side didn't have one of these, I was holding up the bump stop.
My neighbor said yeah it did I put it with the used parts. So, we had to take the first strut off and put it on again, this time with the bump stop.
I'm not to impressed with KYB shocks and struts. I remember when I did my truck, I cut the strap and we had a hell of a time to compress the shock to get it on. All of the strut inserts and shocks were IMO were way to easy to compress and took 10 seconds to fully extend.....the ones that were on the car was useless though and wouldnt extend at all.
thanks to garyfish and archinstl for the part#s for the upper mounts on the struts and said they were a killer deal......My old ones were ridiculously squashed.
