FS: 83 Tercel 4wd $600 obo
donaldc
Post by donaldc »
I have an 83 tercel SR5 4wd wagon that I just no longer need. The car is a 5 speed with EL, ac, and has the inclinometer. The car is white with the blue & Gray interior. The engine and clutch have less than 80k on them, the engine was purchased from advance autoparts, the car also has had a new radiator, starter, voltage regulator, alternator, timing belt, water pump, thermostat, fuel pump, brake pads, brake shoe, and front rotors replaced within the past 15k miles. The car runs really good, but it has a lot of rust and the driverside exterior door handle has come loose on the inside of the door. I'm located near Asheville, NC.
donaldc
Re: FS: 83 Tercel 4wd $600 obo
Post by donaldc »
I'll post photos later.
