TVSV leaks PETROL
TVSV leaks PETROL
So if I can't replace this TVSV, I can probably make it work, it's not cracked or anything. But it tends to leak a little GAS (!) when I start it for a sec and shut it down cold. Float bowl looks good, but output smells rich. Is this a floater or jets issue? I'm worried there may be gas getting into the coolant or something-what would back up gas all the way to the TVSV valve? I'm currently correcting the abuses of her previous owner (and oh yes, the Tercelerator WILL be cherry) so some vac lines may still be wrong, valves are next. How can I avoid bursting into flames?
-CASE
See this thread for a possible fix http://www.tercel4wd.com/forums/viewtop ... light=tvsv
gas to vac lines
That was very helpful, also, the 'much better than chilton's' vac diograms posted by some tercelerated genius called anarchisto or something
(viewtopic.php?t=2810)
was also very helpful. I have one of those abused tercs where the vac lines where hooked up at arbitrary points, then the dumbkopf mechanics fixed it with carb adjustment (grumble grumble) I thought I had the vacs worked out, but I just started learning about the AAP- and guess what?! the big one way valve in the hose going back to the top of the carb was in backwards! So I got an easy free fix, and once the vac stopped backing up there, the AAP stopped pushing gas into the TVSV! I'm still gonna seal the TVSV, and check out my AAP, but this is a case where a little helpful info did a ton of good-'YALL RULE!, thanks
-CASE
Re: gas to vac lines
Well, I am very much a Liberal, but not quite an anarchist ('cept maybe to George & Dick & Karl...).CASE wrote:...called anarchisto or something.
Archinstl, I stand corrected
A genius by any name... Since I straightened out the vac stuff, and lubed up the outside linkage on the carb, all the intake probs that made me want to rebuild my carb are majically going away. When I bought it it was a 3-cyl heavy smoker, now after minimum $$ and effort, the intake and ignition is "stock cherry"
Anyone wishing for carb rebuild, without doing vac lines, ign system, and fuel filter first should note this
-CASE
GOT IT< THANKS
there's a hole in my AAP valve diaphragm, most parts stores deny the existance of this elusive membrane, if you have gas in your bottom TVSV vac line, you need one too. Mine's plugged up for safetey till I can find the $$ for a salvage trip. So I have to warm up the engine before drag racing, till I can find the part-huh huh
-CASE
you could simply by-pass the whole set-up and allow the vac advance to run the way the BS car always did (BS= "before smog").
You need to consult the manual to verify where the distributor draws the vacuum from before it goes through the TVSV and connect it directly, and block off the other vac lines. T
his valve cuts out the vac advance (which only operates at the part load condition, as in fwy cruise speeds) to presumably reduce emissions, and it allows the advance to operate "normally" after the engine gets hot. When the advance kicks in it cools the engine and the exhaust temps (and improves the economy). So it seems to me it would be best to allow the vac advance to always be engaged (espcially if there is something malfunctioning with the TVSV system).
Having vac advance all the time is next on my list, It's hard to stop myself, but i'm trying to get everything working the way it was designed before I get started on mods, that should help me through smog test, but I heard you talking about this vac line bypass in another thread and it sounds like a really good idea. Not gonna mess with the advance 'till I get timing right, it's not far off now, only chortles when I should'a geared down and missed it-deisles a tiny bit ,could be the super hot BOSCH platinums(I'm only keeping them in there because they're expensive, I don't trust them)but I might need to play with the carb a little more, the choke, cold idle, and warm idle are all good, but I'm only getting like 26-30MPG, It has over 200k miles, but I know this car could do better than 26MPG If I set the timing and fuel mix a little better-yall have been really helpful-thanksPetros wrote:you could simply by-pass the whole set-up and allow the vac advance to run the way the BS car always did (BS= "before smog").
-CASE
If the other stuff in the kit is stuff I need, I'm totally on it, otherwise it's SALVAGE YARD TIME! I'ts funny, Autozone is one of the places that didn't believe in the AAP 'till I showed them a picture of it in a manual "what is it really called?when you say diaphragm, you mean the whole pump?Do you mean it's some kind of valve?" they got very close to asking if my Mommy knew that I was in a parts store-I'm 34Dangit! I wonder if they would give me this kind of jib if I asked for an Axial Turbined VIBflexor, that might be funjimpomm wrote:Case there is a AAP diaphragm in the sorrenson rebuild carb kit from autozone
-CASE
Bosch plugs aren't so good in cars prone to ping...they cause more of it...though they last a long time. NGK V-powers work good.
Some parts you need to find at the Toyota dealer? That diaphram shouldn't be too much.
We let ARCHINSTL moderate and stuff just to keep him out of trouble and so we know where he is at all times.
