1.5L to 1.6L
1.5L to 1.6L
hey i was looking up on the tercels history and its engines i got 53kw 3a-c motor and they reckon with the 1.6l 4a engines the strokes the same but the bored is bigger can the 3a-c be bored out or isnt the head and blok big enough
1983 tercel 13inch speedy mags 185/70/13 tyres pedders heavy duty springs(rear) rebuilding car stereo deck clarion dxz766mp clarion splits on the way kenwood 6x9 rear fill jbl subs 12inch
3/4 done exhaust 2inch monza 4inch tip cannon
bolts right in
http://www.tercel4wd.com/forums/viewtop ... highlight=
that is the link to my pull of the 3a, swap everything over and drop a 4a right in it's place.
Helliphino.com
Helliphino.com
bit off topic but can i get a lumpy cam for this 3ac engine and will i need to have better valve springs or will they be alrite and how much is it for a lumpy cam aus?
The 3AC cannot be bored out to the same size as the 4AC. Max recommended overbore doesn't even put you close. The difference is something like 3mm of bore, way more than you can do with a simple overbore. Maybe if you went so in-depth as to do a sleeving job.
http://www.paradiseracing.com
