A/C Compressor Mounting Bracket
I am in need of an A/C-Alternator mounting bracket for an 86 Tercel. It needs to fit the "clamshell" type alternator. The brackets on my 83 and 84 parts cars are for the older style alternator and won't fit. I'd like to get the A/C in this car by the first weekend in June and the bracket is the only thing holding me up. Any help will be appreciated.
Re: A/C Compressor Mounting Bracket
[quote="Chris"]I am in need of an A/C-Alternator mounting bracket for an 86 Tercel. It needs to fit the "clamshell" type alternator.
i may have one but i'm not sure if its the one you need. i'm not familiar with the differnt brackets.
the air cond/alt mount i have is for a clamshell alternator. assuming that clamshell means two mounting ears on the alternator with about a 2-1/2 - 3" gap between
its a heavy unit
i do not know what year tercel it came from
you can have it for shipping costs
its a heavy unit
hendrix...thanks for the reply....sorry I haven't gotten back to you sooner...I've been in CO doing a job. I am not sure of the measurement at this time, as I am not at home. I will check this afternoon and measure the mounting space then get back to you. I wish I knew how to post a photo..
Thanks again
Thanks again
Chris wrote:hendrix...thanks for the reply....sorry I haven't gotten back to you sooner...I've been in CO doing a job. I am not sure of the measurement at this time, as I am not at home. I will check this afternoon and measure the mounting space then get back to you. I wish I knew how to post a photo..
Thanks again
last evening i measured the alternater mounting spot at abt 2-9/16" wide
Unfortunately that sounds like the bracket for the older external regulator style alternator. That style has an external cooling fan mounted just behind the drive pulley. The bracket that I need is for the internal regulator alternator that has the cooling fan mounted internal of of the alternator case. The mounting for the alternator has a spread of about 2 1/4".
Thanks for the time and effort you took in checking for me.
Heh.... When I swapped engines, I couldn't splice the internal-style into the 84's setup, so I tried to put the external on the 86's bracket... After getting EVERYTHING into the compartment, I had to take the AC Compressor out (pain in the ass) and I think the starter as well, then swap brackets. May not sound like much, but after a day of wrenching and hoping for that first crank, it was near the last straw.
