1986 Tercel 4WD Sweden restoration
Re: 1986 Tercel 4WD Sweden restoration
It is a 3A engine. Im still looking for a 4A to put in it. Havent sourced one i want to use yet. Might have another 3A if a guy i helped will replace his engine. He had low compression on one cylinder. Either a burnt exhaust valve due to a leaky intake or headgasket. Either way fixable issues. Then i might have a engine i can play with.
1986 Tercel 4WD, Red, 170000km, restored.
1987 Toyota Corolla Dlx hatchback, 250000km Sold =(
1988 Toyota Corolla touring 4wd, estate restored!
1973 VW T2 Partybus!
1964 Heinkel Trojan, planned restoration
1963 Triumph Herald, currently under restoration.
That's interesting considering I have a parts catalog claiming they have 3A-C engines.Esaus wrote: Mon Sep 16, 2024 3:44 pm It is a 3A engine. Im still looking for a 4A to put in it. Havent sourced one i want to use yet. Might have another 3A if a guy i helped will replace his engine. He had low compression on one cylinder. Either a burnt exhaust valve due to a leaky intake or headgasket. Either way fixable issues. Then i might have a engine i can play with.
K-Business
- Nordical25
- My tercel:: 1x86, 2x87
I have a couple of Sweden manuals and they state too that Swedish cars had 3A-C engines. The engine label says usually 3A but the cars have usually catalytic converter and extra emission stuff on at least later Swedish Tercels. Swiss Tercels should have additional emission equipment too.terceldude wrote: Thu Oct 03, 2024 1:29 pmThat's interesting considering I have a parts catalog claiming they have 3A-C engines.Esaus wrote: Mon Sep 16, 2024 3:44 pm It is a 3A engine. Im still looking for a 4A to put in it. Havent sourced one i want to use yet. Might have another 3A if a guy i helped will replace his engine. He had low compression on one cylinder. Either a burnt exhaust valve due to a leaky intake or headgasket. Either way fixable issues. Then i might have a engine i can play with.![]()
But interesting part is that at least Swedish Tercels have point ignition with catalytic converter. So they are kind of unique in that way.
Mine doesnt have any catalytic converter but it does have points ignition. I would have prefered the electric ignition over the points one ive had some issues getting it to work as good as i wanted. Im planning on doing some servicing to the car this week. Valve stem seals and a wheel bearing is a part of it. My tank is leaking aswell so im going to take it down for a third time to go over it.
- Mark
My '81 1st generation Tercel originally had a points-type distributor. I replaced it with an electronic distributor from the 2nd gen Tercels. It fits perfectly. The only thing to modify is the wiring, since the points-type system is 6 volt. There is a big resistor in the engine bay to drop the battery voltage to 6v and you have to bypass this to get the 12v from the battery to the new electronic distributor.
- Nordical25
I have provided instructions of the IIA distributor upgrade now at following topic: viewtopic.php?t=16306Esaus wrote: Sun Oct 27, 2024 7:01 am Mine doesnt have any catalytic converter but it does have points ignition. I would have prefered the electric ignition over the points one ive had some issues getting it to work as good as i wanted. Im planning on doing some servicing to the car this week. Valve stem seals and a wheel bearing is a part of it. My tank is leaking aswell so im going to take it down for a third time to go over it.
My instructions require a IIA distributor from 1983-1987 E8 Corolla 4A engine.
And Marks instructions you can apply if you find older system that is used in 1st gen. L10-Tercels for example.
And I have attached exhaust pipe spare part picture that is straight from Toyotas spare part catalog that shows catalytic converters in European Tercels: https://www.megazip.net/zapchasti-dlya- ... e-17940063#
It says that European spec. 3AC engines manufactured after May 1986 have catalytic converters. So we are talking about 1987 & 1988 model year Tercel 4wd's basically. Finnish Tercels had still 3A's in 1987. So we had no converters, ECRs etc. I know this because I own two Finnish spec. 1987 Tercel 4wd's.
I have also attached a picture of Swedish 3AC system description straight from Swedish manual. You have a 1986 Tercel? Do you still have ECR valves and rest of stuff shown in that figure?
I have those parts yes. It has ecr and the rest of it. all of it works well. i checked and cleaned everything and havent found any issues. Thanks for the nice images!Nordical25 wrote: Sun Oct 27, 2024 11:21 amI have provided instructions of the IIA distributor upgrade now at following topic: viewtopic.php?t=16306Esaus wrote: Sun Oct 27, 2024 7:01 am Mine doesnt have any catalytic converter but it does have points ignition. I would have prefered the electric ignition over the points one ive had some issues getting it to work as good as i wanted. Im planning on doing some servicing to the car this week. Valve stem seals and a wheel bearing is a part of it. My tank is leaking aswell so im going to take it down for a third time to go over it.
I dont recognize the HIC valve mentioned in the picture. I cant remember seeing it on the engine. im going to prob check the carb and drill the holes slightly bigger to juice the car just slightly. the weak engine of the tercel is annoying lol. i have a corolla 4wd 1988 with 105 hp and it runs so much nicer!
INTERESTING! Thanks for the info!Nordical25 wrote: Wed Oct 09, 2024 10:45 amI have a couple of Sweden manuals and they state too that Swedish cars had 3A-C engines. The engine label says usually 3A but the cars have usually catalytic converter and extra emission stuff on at least later Swedish Tercels. Swiss Tercels should have additional emission equipment too.terceldude wrote: Thu Oct 03, 2024 1:29 pmThat's interesting considering I have a parts catalog claiming they have 3A-C engines.Esaus wrote: Mon Sep 16, 2024 3:44 pm It is a 3A engine. Im still looking for a 4A to put in it. Havent sourced one i want to use yet. Might have another 3A if a guy i helped will replace his engine. He had low compression on one cylinder. Either a burnt exhaust valve due to a leaky intake or headgasket. Either way fixable issues. Then i might have a engine i can play with.![]()
K-Business
- Nordical25
I see. I rely purely to manual and pictures. Good luck with carb. drilling. 105hp Corolla must be nicer, since it is newer and has more power. But you can update Tercel engine in many ways. I have been studying engine updates lately. Buy Toyota 4A-FE block and see my updates in technical section. I am sure that you will get a bit more fun out of your Tercel soon. Good luck!Esaus wrote: Thu Oct 31, 2024 12:26 pm I dont recognize the HIC valve mentioned in the picture. I cant remember seeing it on the engine. im going to prob check the carb and drill the holes slightly bigger to juice the car just slightly. the weak engine of the tercel is annoying lol. i have a corolla 4wd 1988 with 105 hp and it runs so much nicer!
- Nordical25
That is good to know. I am also happy that your emission equipment works well. In case you have trouble, please let me know. Then I can explain how to disable that stuff. You are welcome. I have kept the manuals to preserve and to share information.Esaus wrote: Thu Oct 31, 2024 12:22 pmI have those parts yes. It has ecr and the rest of it. all of it works well. i checked and cleaned everything and havent found any issues. Thanks for the nice images!Nordical25 wrote: Sun Oct 27, 2024 11:21 amI have provided instructions of the IIA distributor upgrade now at following topic: viewtopic.php?t=16306Esaus wrote: Sun Oct 27, 2024 7:01 am Mine doesnt have any catalytic converter but it does have points ignition. I would have prefered the electric ignition over the points one ive had some issues getting it to work as good as i wanted. Im planning on doing some servicing to the car this week. Valve stem seals and a wheel bearing is a part of it. My tank is leaking aswell so im going to take it down for a third time to go over it.
I intend to keep the emissions stuff working as is. I have drilled out the carb now and the car runs alittle better. I reokaced the valve seals and been tinkering with the car. I had to repair the gas tank again but its not leaking anymore. The car has been running great since my last tune up and carb fix. I also replaced sway bar bushings in the front as well as had to restore a brake caliper again after it got stuck! It has never been this severe for me before. The discs were glowing and looked like a light was shining out from the wheel. Didnt warp the discs or anything but i had to rebuilt the caliper again.
- Nordical25
It is worth of keeping emission stuff as is if you don't have any problems. My principle is with these cars to avoid fixing things that work fine excluding parts mentioned in service intervals. I have had my share of brake problems too. They use here a lot of road salt, which jams calipers. Therefore I had to brush rust away and treat my calipers with brake paste. So minor jobs like that can come when owning a Tercel 4wd. But at least not everyone else around you has a similar car.Esaus wrote: Sun Mar 09, 2025 1:33 pm I intend to keep the emissions stuff working as is. I have drilled out the carb now and the car runs alittle better. I reokaced the valve seals and been tinkering with the car. I had to repair the gas tank again but its not leaking anymore. The car has been running great since my last tune up and carb fix. I also replaced sway bar bushings in the front as well as had to restore a brake caliper again after it got stuck! It has never been this severe for me before. The discs were glowing and looked like a light was shining out from the wheel. Didnt warp the discs or anything but i had to rebuilt the caliper again.
Great looking Tercel too! I hope you are able to get a 3A-SU in there!
K-Business
