Transaxle install after transmission fix
Hope this thing works after all the work getting it out and rebuilt. This is the poor mans lift out in the yard. In Vermont I have a LOT of tercel parts *85.86 if anyone is close enough to come get them. (S Straffrord).
- SirFoxx
Re: Transaxle install after transmission fix
rebuilt with what parts?
thats a shame to roll a clean looking wagon on its side like that
viewtopic.php?t=16285
1982 4dr Tercel (RIP)
I agree with SirFoxx. I'm sure it was nice to not have to crawl under the car but this approach seems like it would have its own challenges.
What was wrong with the transmission?
Wow... I was shocked when I saw those pics. But this forum could use a jolt, so thanks for providing one. If it works, it's called innovation. If not, well... lesson learned.
No damage to tercel. Just lay out 8 or so tires for it to rest on, Transmission was missing 5th gear. Teeth turned out to be stripped. Support under hubs and door post where the body strength is. I drained the gas first. A lot easier to work on vs a lift where everything is over your head. I have a few spare transmissions to scavenge. And hoards of other parts.
- SirFoxx
no damage? uhuh, sure. i dont think the side of the car is meant to support 2300lbs. but you do you boo boomhebb1 wrote: Thu Jul 11, 2024 4:47 am No damage to tercel. Just lay out 8 or so tires for it to rest on, Transmission was missing 5th gear. Teeth turned out to be stripped. Support under hubs and door post where the body strength is. I drained the gas first. A lot easier to work on vs a lift where everything is over your head. I have a few spare transmissions to scavenge. And hoards of other parts.
These cars have no frame so the body is like an eggshell and has good strength if spread out.I don't see an option to add more pictures to show there was no damage to body. Should I start a new topic?
No need for a new topic, you're good here!mhebb1 wrote: Thu Jul 11, 2024 8:09 am These cars have no frame so the body is like an eggshell and has good strength if spread out.I don't see an option to add more pictures to show there was no damage to body. Should I start a new topic?
For adding more photos: below the white box, just click on 'Full Editor & Preview.'
Then below the white box on the next screen, click on the Attachments tab, click 'Add files,' do that and then click 'place inline.'
