New 88 tercel wagon bigger tires
dak_triad
My tercel:: 1988 toyota tercel 4wd wagon auto
Post by dak_triad »
New to the forum
Just picked up an 88 tercel wagon auto
Had a question about bigger tires
I want to put on A/T tires but am not sure about fit, i was looking at general grabber A/TX 27x8.5r14 with Basset 14x7 wheels. I have a 1.5” lift kit too. Not sure about the offset
Any help would be appreciated
-joe
Re: New 88 tercel wagon bigger tires
dak,
It really depends on your expected use as well as “fit”. I’ve been running and really like 195/75 R14 (25” dia). The 27” tires will fit with some rub on turns and cut down on articulation (very little on our unibody cars anyhow). The power suck may be an issue for daily driving, as a 27” tire will have a roughly 20% longer circumference.
dak_triad
Post by dak_triad »
Thanks man, the smallest A/T tire I could find in a 14” wheel was the 27 at first. Ended up finding 195/75 wrangler A/T’s so I’m going with that.
Thanks again
-joe
Sounds good,
I think the 27” tires would daily fine with the 4.1:1 gearing, buy off-roading may be trickier in the slow crawls/climbs. If I didn’t off-road a few times a year, I would step up to the 27”s.
MrWrench
Post by MrWrench »
I recently purchased a set of Forceums ATZ-R. They're $280ish on eBay and are definitely worth it.
1983 AV-II Sprinter Carib.
dak_triad
Post by dak_triad »
Those are rad! I ended up getting some 195/75r14 wrangler AT from my buddy who works at a tire shop. I really like them but my problem no is rear shocks, the previous owner installed air shocks which I really liked but with the lift I put on they’re stretched out a little more than I’d like and it bangs around on any big bumps in the road.I have it set at 10psi, any more it bounces around like a carnival ride. So now I need to find different shocks and maybe new springs, I’d actually like it if it was about an inch lower in the back, I need to get a rack and basket to put a spare up top so maybe the weight will bring it down a little
terceldude
Post by terceldude »
Looks great! Though any off-road fans notice you enough to promote your car?
K-Business
