Turbo 4age tercel
Re: Turbo 4age tercel
that is a lot of fine effort and expense going into a funky old econo-box of a car. that will really be something unique, and quite the sleeper!
I am curious what a "DIY megasquirt" is that you are using. it is homemade? can you make one inexpensively? or it is modified megasquirt (that is not particularly economical over using a factory ECM from picknpull).
Also, how difficult it is to adapt the coil-on-plug ignition system from the Yaris? I have a long neglected 4age swap project for a T4wd in my garage, that I have been mulling over fuel and ignition alternatives (I already have a corolla GTS fuel tank to install in it). I was going to install a first gen MR2 ECM in it, and the stock 4age distributor, to get it running. but up dating the ignition to eliminate the distributor would be a great up grade, saves weight, complexity and improved performance. Being able to optimize the EFI for better low end torque and improved economy would also be a great. If it takes a lot of fiddling and tinkering I may just save it for later, because I may never get it done, unless it is a fairly easy upgrade.
your efforts are inspiring to those of us who struggle to just keep our old econoboxs running.
- SirFoxx
Sorry peter, I didnt see your reply.Petros wrote: ↑Wed Nov 23, 2022 7:45 pm that is a lot of fine effort and expense going into a funky old econo-box of a car. that will really be something unique, and quite the sleeper!
the diy megasquirt is for the person thats 100% competent using a soldering iron, and has a good setup, itll save you like $150-200 off the initial cost, at the risk of you putting it together correctly. The factory toyota ecu I dont think can handle boost whatsoever, unless you were to find a 4agze ecu (gooood luck).
If you are going COP, you need standalone ignition. The megasquirt can handle it, assuming you are able to give the ecu the required cam / crank signals. I am using a 36-1 cam input for mine, using the factory cam gear with one tooth ground off.
With the 4age, "optimizing" it for low end torque is not strictly an ecu problem, its mainly the cams. I've got custom cat cams in my 7age that lower the power band, and broaden it to be between 2500-6500 rpm, and its great. Though, if you truly want torque, I'd look into getting a stroker kit for the 7a engine.
Having fixed the ole mercedes and dumping the hyundai, I've been working on the turbo tercel again. I test fitted the COP kit, and found a radiator hose that'll work for the upper line.
I believe I have most of everything purchased to start the wiring. However, before I do that, I need to find two spots on the firewall to mount waterproof bulkhead connectors. The ecu cannot be in the engine bay, and I dont want to use grommets as if I ever have to disconnect the two, It'll be next to impossible to do so due to the parallel port plug the ecu has, and the 9000 connectors in the engine bay.
Next step that I want to do is change brake discs. I have dotted n slotted rotors from the yellow car, however, the wheel bearings need to get shimmed inside the knuckle, and said shims dont exist anymore (to get the rotor off, you have to pull the spindle, then press it back in. 0/10 awful design) As of right now, I cannot get the orange cars spindles off using a slide hammer, so I may just reuse the yellow cars spindles and have a machine shop make the shims at a later point.
1985 4wd Tercel SR5 (RIP)
- Nordical25
- My tercel:: 2 4wd 1987's. One with 4a, other with 3a
Nice updates. 4A-GE starts to look like engine from 2000's with coils on the top. Luckily Tercel has lots of space for those connector spots through firewall. I guess that they will depend just on placement of your ECU inside your car.
- SirFoxx
Ehhhh not really. The particular bulkhead connectors I have require a flat surface for the seal to mount to, and the firewall is anything but flat. I have found one good spot, just need to find / make another. Plus, Theres not really all that much room since this car also still has all the AC components on the interior.Nordical25 wrote: ↑Sun Jan 22, 2023 1:30 am Nice updates. 4A-GE starts to look like engine from 2000's with coils on the top. Luckily Tercel has lots of space for those connector spots through firewall. I guess that they will depend just on placement of your ECU inside your car.
- Nordical25
AC on 1st gen Tercel! I could have never imagined AC on 1st gen Tercel. Is it OEM one? If it is, you are the first one to tell me that 1st gen Tercel did get also an AC. Then I also start to understand why it is challenging to find a good spot for that connector.SirFoxx wrote: ↑Mon Jan 23, 2023 5:54 am Ehhhh not really. The particular bulkhead connectors I have require a flat surface for the seal to mount to, and the firewall is anything but flat. I have found one good spot, just need to find / make another. Plus, Theres not really all that much room since this car also still has all the AC components on the interior.
Anyway that will be one luxurious 1st gen Tercel with AC and 4AGE. What else accessories it will get? Power steering, cruise control or possibly even Tacho?
- SirFoxx
Yes, AC was an option on the first gens, and its fairly common, depending on the climate the car came from. Of the four first gens ive own(ed), only one didnt have AC as it was a complete base model.Nordical25 wrote: ↑Mon Jan 23, 2023 12:23 pmAC on 1st gen Tercel! I could have never imagined AC on 1st gen Tercel. Is it OEM one? If it is, you are the first one to tell me that 1st gen Tercel did get also an AC. Then I also start to understand why it is challenging to find a good spot for that connector.SirFoxx wrote: ↑Mon Jan 23, 2023 5:54 am Ehhhh not really. The particular bulkhead connectors I have require a flat surface for the seal to mount to, and the firewall is anything but flat. I have found one good spot, just need to find / make another. Plus, Theres not really all that much room since this car also still has all the AC components on the interior.
The sr5 1st gens came standard with a tach cluster, larger three spoke steering wheel, and a special shift knob. I have both the wheel and cluster, which will be getting put into the turbo 4age hatch.
power steering...while I do like the manual rack, I think once the car is running, I will convert to an electric prius column. They are pretty easy to install, and with it being a toyota part, my 1st gen sr5 steering wheel should theoretically fit!
- SirFoxx
Got the iac valve installed. The factory 4age one was a weird wax based thermostat valve, which in theory works, but I've heard that they get kind of questionable with age. Also, with me switching to a standalone fuel and spark management system, I need to be in control of the IAC. I am using one from a Ford 4.6 modular with adapter plates to suit. The bracket is super ugly as my fabrication skills are pretty bad, and the settings on the welder got all messed up by my roommate.
Also also, welded the fuel pressure regular bracket under the shock tower. I was not happy with how I had it a fixed with a bolt, and welding it will not be a detriment either.
- Nordical25
You had really great options then on 1st gen Tercel. I have never seen even Tacho on European ones. It could exist on some few ones but most cars come without tacho for sure. Prius electric column sounds interesting. Hopefully we will see also incoming pictures of that when your project proceeds further.
- SirFoxx
There were a few other options, such as the "chrome package", pop out rear windows, carpet, etc. The tach was exclusive to the sr5 hatch. Also, fun fact. The DLX hatchbacks had a tripometer, whereas the two and four-door sedans did not even though the clusters are otherwise the same.Nordical25 wrote: ↑Wed Jan 25, 2023 11:39 pm You had really great options then on 1st gen Tercel. I have never seen even Tacho on European ones. It could exist on some few ones but most cars come without tacho for sure. Prius electric column sounds interesting. Hopefully we will see also incoming pictures of that when your project proceeds further.
Rolled the turbo project outside so I could work on another car in the meantime. Trying to get said car -- '86 Lincoln Continental -- ready for when my dad visits in a few weeks. Need similar work to what my Mercedes need--front end replacement, engine maintenance, etc. Nothing too major.
- Nordical25
Ok, then I understand well why hatches are so tempting ones.SirFoxx wrote: ↑Sun Jan 29, 2023 11:53 pmThere were a few other options, such as the "chrome package", pop out rear windows, carpet, etc. The tach was exclusive to the sr5 hatch. Also, fun fact. The DLX hatchbacks had a tripometer, whereas the two and four-door sedans did not even though the clusters are otherwise the same.Nordical25 wrote: ↑Wed Jan 25, 2023 11:39 pm You had really great options then on 1st gen Tercel. I have never seen even Tacho on European ones. It could exist on some few ones but most cars come without tacho for sure. Prius electric column sounds interesting. Hopefully we will see also incoming pictures of that when your project proceeds further.
You seem to have many vehicles from that era. It is good since you start to learn several alternative technical solutions for your custom builds. I learned also a bunch of tricks from my Kadett project like adjusting ignition to my Tercel projects.
- SirFoxx
the newest car i currently own is from '86 -- my 7age t4wd and the lincolnNordical25 wrote: ↑Fri Feb 03, 2023 12:04 pmOk, then I understand well why hatches are so tempting ones.SirFoxx wrote: ↑Sun Jan 29, 2023 11:53 pmThere were a few other options, such as the "chrome package", pop out rear windows, carpet, etc. The tach was exclusive to the sr5 hatch. Also, fun fact. The DLX hatchbacks had a tripometer, whereas the two and four-door sedans did not even though the clusters are otherwise the same.Nordical25 wrote: ↑Wed Jan 25, 2023 11:39 pm You had really great options then on 1st gen Tercel. I have never seen even Tacho on European ones. It could exist on some few ones but most cars come without tacho for sure. Prius electric column sounds interesting. Hopefully we will see also incoming pictures of that when your project proceeds further.
having worked on a handful of different cars you quickly learn that the concept is the same, but execution is wildly different. Example, the water pump on the tercel is held on with three easy bolts, whereas on the lincoln every single gosh darn accessory and bracket has to come off the change the pump
opel kadettes are awesome! you should post some pictures if you have any!
