Hello--
I need some advice with the drums on my 7age wagon.
Ever since like day 15 of owning my wagon, the brake pedal has complete ass -- no pressure, car nose dives when you hit the pedal. I've dealt with it, and tried remedying the issue by changing boosters, masters, and wheel cylinders to no avail. The issue continued when switching to a known working 1st gen tercel booster and a ford probe master (used for clearance with the 7age swap), so I know the issue isnt at the brake pedal. When I did some investigating some time back, I found that one, or both, cant remember, of the drums arent doing anything. After a vigorous readjustment session, I got the pedal feeling alright, with the drums having slight drag when rotated. A quick drive around the block aaaand its back to feeling like ass.
I've ordered all new brake hardware (minus the adjusters cause they are discontinued everywhere for the 4wd's) to see if I can fix this. My drums are fairly worn, so it wont be a complete parts cannon.
Before I tear into this, I have two questions:
1. Can someone post a clear picture with the drums off for reference?
2. I know the adjusters are CW and CCW. Which side is CW and CCW? Ive had the adjusters out and want to make sure they went back in on their correct side.
Drum brake help
- SirFoxx
Drum brake help
viewtopic.php?t=16285
1982 4dr Tercel (RIP)
- SirFoxx
Re: Drum brake help
bump
Re: Drum brake help
Hey Keegan,
I can pull a wheel this weekend if you don’t have a pic yet. If you would like a hand some Saturday or Sunday afternoon, let me know.
The “keeper” stops them from spinning upwards correct? If so AND the threaded portion of the spacer goes to the rear, then it would be driver’s side “reverse” thread and passenger’s side would be “normal” thread.
- SirFoxx
Re: Drum brake help
a picture would be nice, as well as 100% confirming which way the adjusters go. mrwrench gave conflicting info, but isnt sure as he only did one side at a time.NWMO wrote: Thu Dec 08, 2022 6:43 am Hey Keegan,
Re: Drum brake help
Will do.
- Nordical25
- My tercel:: 1x86, 2x87
Re: Drum brake help
Hi,
I visited my garage today and took these pictures of my loose spare parts. This is my spare left side since cable is on bottom and cable goes towards front of car:
- Nordical25
Re: Drum brake help
And this is my spare right side. However these are only loose spare parts so maybe it is better that NVMO pulls out drums if he has well working system during weekend.
Re: Drum brake help
I am wondering if master cylinder was not bench bled. Or not bench bled properly. Or bench bled improperly and is now damaged
- SirFoxx
Re: Drum brake help
not the case. i rebuilt the drums with fresh hardware, and got everything set. i kept having a weird false set with the adjusters where i would get them set where the drums were snug, i would pull the drum off, put it back on and it was loose again. got it to a point where it wasnt doing that and now everything is fixed!xirdneh wrote: Sun Dec 11, 2022 3:07 pm I am wondering if master cylinder was not bench bled. Or not bench bled properly. Or bench bled improperly and is now damaged
