convert auto trans to manual?
Just wondering if anyone has done a conversion of an automatic to a manual transmission. Are driveshafts different length? Neutral safety switch wiring easy to transfer? Any other tips? Thanks.
Re: convert auto trans to manual?
Inactive member fingers did this back in '05-6 as I recall. He did a writeup on it - pretty detailed; do a Search using his name, and in either Repair Guides or Repair Questions. I think someone else did this as well, but am not sure.
Lil Beast
Post by Lil Beast »
I'm gonna be on the process of doin this within a couple of weeks! Waiting for my clutch! Looks pretty straight forward, the neutral swicth is pretty easy to rig if you absolutely want it! Make sure you got all the parts of the donor car! Maybe some hole to drill to fit the pedal but dunno yet! I'll be trying to find FINGERS thread to see what I'm up to!
The driveshafts seems to be the same lenght, the diffs are the same!
Edit: just went thru the 204 post fingers wrote and found 1. Unfinished write-up "engine swap mania"! Nothing clear enough on the conversion! But with a good manual and the fsm you should manage! I will be able to answer you better in few weeks when done! Hopefully just a few weeks!
Labine R.
i did it several years ago
if you need info
PM me and i will send phone number
its not to bad of a job
MY BAD! :oops:
I thought it was fingers who did the writeup. It was actually inactive member tooldudetool - pretty good, too:
This is the link in Repair Guides - https://tercel4wd.com/forums/viewtopic.php?t=1443
I guess you rig the neutral safety switch to the clutch switch. I would leave it out, I hate clutch switches...very annoying and for 80 years manual trans cars never had them, we do not need them now either.
I did it on another brand of car, usually straight forward. But there can be a lot of small detail parts that are different, so if you get the whole donor car to get parts it is much easier. There is always some linkage, piece of trim, switch or bracket you will forget to get, having the car right there is a big help in keeping the swap moving. Usually the driveshaft is a different length, and you need rear cross member and rear mount as well.
Sounds great. I do have a donor car. I just wanted some feedback from other people who have gone through it. I did a conversion once on another type of vehicle and it was nothing but trouble! I will look up the thread. Thanks.
Lil Beast
Post by Lil Beast »
I've read thru the thread it's nicely done! Looks like what I've expected, straight forward, I did it on other vehicles before, so do have a good background on the subject! But always like to do some research before! That thread is all you need to know!
Labine R.
eightyfive4WD
My tercel:: 1985 Tercel 4WD 5 speed wagon
Post by eightyfive4WD »
I am about to begin the automatic-to-manual surgery on my Tercel!
Just picked up this carcass in Sierra Vista, AZ. 400+ mile round trip but well worth it.
All the parts necessary in one inclusive package. Very nervous for the operation but very glad I've got a full donor car to pick pieces from.
Take heaps of photos before you disassemble. Best of luck!
SirFoxx
Post by SirFoxx »
eightyfive4WD wrote: Mon Sep 26, 2022 2:10 pm Image
I just did an auto to manual swap on my fwd '85 hatch. Hardest part is drilling the holes for the clutch pedal assembly and the hole for the clutch cable assembly. I recommend drilling out the cable guide on the firewall and stitch welding it into your car. You'll also need to remove your brake booster as one of the clutch pedal bolts is located right behind it.
brake pedal, you can either swap it or take a sawzall to it.
1985 4wd Tercel SR5 (RIP)
eightyfive4WD
Mattel wrote: Mon Sep 26, 2022 11:38 pm Take heaps of photos before you disassemble. Best of luck!
I definitely will! 8) Thank you
SirFoxx wrote: Tue Sep 27, 2022 10:13 am
Thanks for the tips. I'm trying to soak up all the advice from the forum right now that I can. Definitely my biggest car project so far. But I'll have help from a friend with basically a machine shop in his garage so I'm set.
eightyfive4WD
It'll aaaaaalll be worth it for those 3.73 gears on the highway... :mrgreen:
The only hole you should have to make is for clutch cable thru firewall . The brake and clutch pedal mountholes should be there
SirFoxx
Post by SirFoxx »
xirdneh wrote: Tue Sep 27, 2022 9:40 pm The only hole you should have to make is for clutch cable thru firewall . The brake and clutch pedal mountholes should be there
just having done the conversion, the clutch pedal holes are 100% not there.
